Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 07-15-2004, 09:12 AM
Glennyboy Glennyboy is offline
Unhappy 92 325 no start
My battery went dead overnight along with the starter motor 140,000 miles,replacing the battery the starter turned over slow and made some grinding noise, but would not start, then the starter motor made strange noises and died.I replaced the starter motor what a nightmare that was.Upon replacing the two fuel lines to the metal pipes under the intake manifold hoping they were right....fuel supply to the front rail, rear rail return line. Anyway when all done the car would not start i pulled the front spark plug and it did smell of gas, did a compression #1 and it was only 50 ibs could this be to much gas washing the oil from the piston rings or timing chain problem. Today i will replace the spark plugs.
Glenn.
Old 07-15-2004, 09:34 AM
Skycity_BMW's Avatar
Skycity_BMW Skycity_BMW is offline
Send a message via Yahoo to Skycity_BMW
Re: 92 325 no start
how did it run before this ? ?
Old 07-15-2004, 12:52 PM
Re: 92 325 no start
yes the car ran ok before this,i replaced the spark plugs but before i put the coil back on #1 i ran the compression tester hose in the plug hole with finger over the end had it cranked over, low compression but not firing on the compression stroke.?
