Old 07-15-2004, 08:53 AM
Chevysmallblock Chevysmallblock is offline
thermostat
I just changed from the stock 195 degree thermostat to a ac delco 160 and my 92 camaro seems to be running stronger. Is this just me or is this normal
Old 07-15-2004, 10:43 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: thermostat
its normal. a cooler engine runs more efficiently and makes more power...
Old 07-15-2004, 07:03 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: thermostat
Your fuel economy will also go down and your emissions will go up
1991 Camaro Z28
Old 07-15-2004, 09:55 PM
Re: thermostat
yeah i never understood that: why does the fuel economy go down??
Old 07-15-2004, 11:49 PM
DaMoNe6969's Avatar
Re: thermostat
When your engine is cold and warming up, it runs a pre set fuel/air mixture ratio from the ECM.. Once it reaches operating temp, it turns to the oxygen sensors to provide the fuel/air mixture info.. A 160 degree thermostat wont let the engine fully reach the normal operating temp so your air/fuel might be messed up while your drivin'
If your interested, you could get a hypertech thermomaster power chip.. It'l lower your engine operating temp, turn your fans on earlier and allow you to run a 160 degree tstat..
1991 Camaro Z28
Old 07-16-2004, 09:24 AM
Re: thermostat
what is the operating temp, 180?
Old 07-16-2004, 11:52 AM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: thermostat
Yup, that thermomaster chip will let you run the cooler temp and not sacrifise the emissions and fuel economy
Old 07-16-2004, 12:12 PM
Re: thermostat
word...
Old 07-16-2004, 06:07 PM
Re: thermostat
Sweet i ordered the Chip this morning and it will be shiped tomorow I will report on the results
Old 07-16-2004, 10:56 PM
Re: thermostat
word, again...
Old 07-22-2004, 12:51 PM
Re: thermostat
The chip just came in. I got the thing in in like 15 minutes and instant improvment. My rpms settled back down fron the 160 thermostat change and the hps went up enough to feel the difference TBI CHIPS is ok in my book
Old 07-22-2004, 12:59 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: thermostat
wrong, since you have dropped 35 degrees in temp, everything is cooer including your aircharge. sooo, colder air is more dense, more dense air needs more fuel to support it. There ya go
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-22-2004, 01:05 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
Re: Re: thermostat
the ecm has nothing to do with the fans. the fan(s) run on a completely diferent circuit.
a relay is powered by the ignition switch, and is tripped by the fan switch and the AC switch
Old 07-22-2004, 07:45 PM
DaMoNe6969's Avatar
Re: Re: Re: thermostat
I said the a/f ratio might be off.. And although the denser air will compensate a little bit.. Your engine is still in open loop operation, and it cant increase or decrease fuel delivery accordingly, therefor the engine wont be running at peak efficiency.. There is no closed loop gain
1991 Camaro Z28
Old 07-22-2004, 07:51 PM
Re: thermostat
actually that might not be entirely true. i have a diagnostic scanner for OBD I/II cars. i also have a 160 degree thermostat and when i got the scanner i obviously used it on my car. i used the real-time monitoring feature and it said my car was running in closed loop...
