Old 07-15-2004, 08:25 AM
debear debear is offline
Unhappy 97 Grand AM Shifts hard between 1st and 2nd. 97
I thought I had this problem fixed. We had found a vacuum line broke into. The shifting improved, but the longer you drive the car the worse the shifting gets. Should I replace the vacuum modulator and see if this works before taking to dealer? Any help would be greatly appreciated.
Old 07-15-2004, 11:15 AM
fluffybunny fluffybunny is offline
Send a message via AIM to fluffybunny
Re: 97 Grand AM Shifts hard between 1st and 2nd. 97
hmm, is yours an auto or manual? mines an auto and ive got a real hard shift 1-2nd. maybe we got the same problem.....i got my tranny rebuilt new torque converter and all....then the car sat for about 1.5 years with a blown engine ....no ive got it running and i figured it was just dry seals and such....it got better over the past 3 months but still shifts hard.....scratches between 1-2.....
Old 07-15-2004, 02:48 PM
Re: Re: 97 Grand AM Shifts hard between 1st and 2nd. 97
It's an automatic. I just replaced the vacuum modulator and it made no difference. The guy at NAPA suggested an additive, guess I'll try that next.
Old 07-15-2004, 09:14 PM
redhot97GAGT redhot97GAGT is offline
Which addititive? Let us know if it works!
Old 07-16-2004, 01:35 PM
Lucas transmission fix. Bought it from NAPA. Fluid is slightly overfilled already so will have to drain some before I can add it. Will let you know if it works.
Old 08-02-2004, 07:27 AM
Lucas additive didn't help. A service bulitin I read suggested replacing the control valve body assembly with the updated control valves. Bulletin# 67-71-64.
Does anyone know about what the cost would be if done by dealer. If this turns out to be the problem?
