Old 07-15-2004, 02:19 AM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
egr valve
my ls started idling higher than normal (erratic between 1000 and 1500) and the ecu threw the code for the EGR.
now.. i never hooked the EGR up with any wiring or vacuum and have put nearly 10k miles on the engine in the civic.
how does the EGR work?
how could the ecu throw a code if it was never hooked up.. could the ecu finally have recognized the problem and is trying to compensate?
how do i hook it up vacuum wise.. i hooked a vacuum line from my intake mani up to it and the engine idled down but lost all of it's low end.. ran choppy when accelerating.. only in 2-3k RPM over 3k felt ok
there's a 3 wire plug from it, if i used the DX harness for MFPI swap will i have to wire teh EGR directly to the ecu? the EGR is mounted on the intake mani and i don't have the part that mounts to the firewall.
it's a 90 head and ecu.
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 07-15-2004, 11:31 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
Re: egr valve
well i have an egr valve and i dont think a damn thing is connected to it. it might have just gone bad or something though. how bout a pic to see this egr valve, maybe i can check it against what i have and compare.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
