Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-15-2004, 01:26 AM
Oni_no_style Oni_no_style is offline
95 check engine light
Okay, I have a 95 dodge neon Highline 4dr. When I purchased it 4 months ago it had SERIOUS issues. the previous owner treated it like crap, the oil had rarely been changed, the coolent was low, and it was 3quarts of oil short. After I fixed all this, I had to rewire the duct tape job they did on the radiator fan and replace the spark plugs, wires, and oil cap.
After driving the car to Oklahoma city (30 minutes of highway travel from shawnee OK) the check engine light came on. I pulled into my dads driveway and looked around, finding my 3 quarts of oil all over the underside of my car. with a little reasoning I started cleaning and found it to be the oil pan gasket was leaking, so I replaced it. this solved the check engine problem. However, every time I do more than 20 minutes of Highway time my check engine light comes on, even though I'm not leaking any fluid, not over heating, and not burning anything. Worse over, the light will go off for no reason the next day if I don't do any highway time.
Any ideas?
It could be worse - its worse.
Old 07-15-2004, 02:10 AM
Pedros91 Pedros91 is offline
Send a message via AIM to Pedros91
Re: 95 check engine light
turn key on and of 3 time inc 3 seconds and you're check engine light will flash the code u have and look it up at local parts store like auto zone they will tell you what the code means
Old 07-17-2004, 04:31 PM
I must be reading the code wrong because I didn't get only two numbers. It first flashed once, then in a sequence of numbers. I'll list then in order.
1 2 3 2 5 5
is this actually three codes that its giving? (12, 32, 55) or am I reading it wrong?
Old 07-17-2004, 09:24 PM
I think that it's right 12 32 55
Old 07-19-2004, 10:57 AM
209 neon's Avatar
209 neon 209 neon is offline
take it to the shop....
STOCK MOTOR 14.5 with minor bolt-ons:
ICEMAN COLD AIR INTAKE
HEDDMAN HEADERS
CATCO HI FLOW CAT W/STOCK 2.25 PIPING
TTI RACE PULLEY
APEXI N1 EXHAUST
MSD COIL
MAGNACORE WIRES
ENERGY SUSPENSION MOTOR MOUNT INSERTS
NO POWER STEERING UNIT/ NO A/C UNIT
"RACE ME IF YOU WILL BUT REMEMBER IN THE END ITS STILL JUST A NEON"
Old 07-19-2004, 01:25 PM
Re: Re: 95 check engine light
I don't take cars "to the shop" since I don't trust anyone to have ethics or professionalism these days. There isn't anything a machanic can do in his shop that I can't do in my garage anyway. Thanks for the suggestion, but I could really use some advice like "this part might do it, or maybe this one" rather than "pay someone three times what they are worth to rip you off for four times the parts and five times the labor."
Old 07-20-2004, 05:07 PM
209 neon's Avatar
go to kragen and buy a OBD2 scanner.....
HEDDMAN HEADERS
TTI RACE PULLEY
APEXI N1 EXHAUST
MSD COIL
MAGNACORE WIRES
Old 07-20-2004, 05:21 PM
Thanks for the advice, I have the code now and will be doing the gruntwork sometime this weekend.
Thanks everyone!
Old 07-24-2004, 12:25 PM
ol yeller ol yeller is offline
Neons dot org.
Old 07-29-2004, 10:05 PM
t scaner will not work on the 95 because it's obd1
Old 07-30-2004, 07:54 PM
egr
mine screws up on occassion. The 3 on 3 off is the right way. should be able to take it out and clean it.
Old 08-07-2004, 03:54 PM
lilinaz19 lilinaz19 is offline
Send a message via AIM to lilinaz19 Send a message via Yahoo to lilinaz19
i know this isnt a reply but i have the same problem with my light and i tried the code thing and my light just starts blinking. can anyone help?
Old 08-07-2004, 07:56 PM
ok
it should blink 1time pause 2 times long pause a number of times pause anumber of times long pause,( may do this a number of times if multiple codes) then 5 times pause and 5 times pause. the 1 and 2 always seems to happen for batt code then the 5 and 5 signal end of sequence.
neons.org has the better descript but this is as simple as I know.
Old 08-09-2004, 11:53 PM
ty so much for that, but soon after i wrote that i figured it out. ty again
