Old 07-15-2004, 12:38 AM
snipez's Avatar
snipez snipez is offline
new plugs? new wires?
my car is hurting when its warm out.
battery dies, or close to it. engine is laggy
how can i tell if i ned new wires and plugs? i replaced them 35,000 km ago. i take one boot off the coils and it looks like the coil head burnt a mark into the wire.
could it be rad related? even though car dosen't overheat
coils are fine, vacuum tested the heads, fine
fuel injectors seem to be all in order
anyways, any ideas?
93 grand am v6
Old 07-15-2004, 06:47 AM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
Re: new plugs? new wires?
New wires might be good since you've indicated that there was arching going on. If there are burn marks, that may suggest arching which means that at some point the boot came loose and the spark began to "jump" and in turn burnt the wire boot.
Jake
