Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-15-2004, 12:22 AM
crabby760 crabby760 is offline
whats better mod to buy out of these!!!
i have a b16a ... i'm curious what is a better mod to go for next out of these
either obx stage 3 camshafts with skunk 2 springs/retainers.....
or
act stage 3 clutch kit with 12 lb lightened flywheel....
wich mods do u th ink will get me quicker..?
mods i have as of now are
intake
header
exhaust
mugen ecu
aem camgears
skunk 2 intake manifold
obx crank pulley
all responses are helpfull i want to know whats up
THANKS IN ADVANCE
Old 07-15-2004, 12:38 AM
b16a3sol b16a3sol is offline
Re: whats better mod to buy out of these!!!
if you can get to a dyno, i would say get the cams and put those cam gears to use tuning the motor. that would probably get you more than the clutch.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 07-15-2004, 12:57 AM
so cams would make more difference then a racing clutch and lightened flywheel?
FOOORRR SUUUREEE
Old 07-15-2004, 01:00 AM
can anyone find out what these OBX STAGE 3 cams actually put out in horsepower after tuning on a b16a motor
Old 07-15-2004, 03:46 AM
SenseiAccord SenseiAccord is offline
something about daily driving with a "stage 3" act (extreme pressure plate) will eventually wear out pretty fast in a way. Not wear out the disc but the throw out bearing or something like that. It may say it is for street but it kinda really isnt. you need to do some kinda of other modification. the heavy duty pressure plate should be more than enough and it is a lot more streetable.
Cams, springs and retainers will put out probably a lot more power than a lightweight flywheel. Stage 3 is a pretty big cam i believe. Not even to sure if it is good for daily driving. Probably get rough idle and crap like that. You will get big gains as long as u compliment those cams with other mods and proper tuning.
Old 07-15-2004, 08:23 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea you are going pretty wild with a set of stage 3's, it is gonna be a terrible idle, id say get some stage 2's and the valve spring/retainer combo.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-15-2004, 03:12 PM
does anyone know what kind of number's these OBX CAMS put out ... also i am still running a stock clutch that is why i was thinkking of the new racing clutch and flywheel combo... so everyone things i should get stage 2 obx cams then with springs/retainers
Old 07-15-2004, 03:50 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
obx cams, ive never heard of obx cams. you should talk to a person that actually runs these cams and ask him how streetable it really is because its all talk unless you know someone that actually runs them. kidna like the 404 cams for the ls, people tell me oh its not streetable but then someone who actually runs them says it is streetable, so first hand experience is always better then talk
cams will give you more hp and make you quicker, unless for some odd reason you clutch is slipping with the amount of hp you are making now or if its worn out already, then the clutch will be good
if you go with an act clutch i would recommend hte HD pressure plate with the street disc
Team Lonely Drivers
Old 07-15-2004, 04:35 PM
boosted331 boosted331 is offline
Re: Re: whats better mod to buy out of these!!!
All the camshafts for vtec hondas use the stock primary lobe, or a primary lobe that is marginally bigger than stock to make the transition to vtec smoother. A good friend of mine daily drives a b16 with Toda D's and hondata and his car idles fine.
FWIW, I would never ever buy OBX. Every single other part they make is total shit, and cams are not something that you want to fuck around with cheap shit. On top of that, I've never even heard of OBX making camshafts, and they have no mention of them on their site. Big cams suck without bumped compression anyways, so i'd stay away period.
Old 07-15-2004, 05:18 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
get elbrodbrok or w/e intake manifold. its been proven better than the skunk 2
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
