Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 07-14-2004, 10:13 PM
vegas04taco vegas04taco is offline
Lift and tires question
Hey all. I have an 04 xtra cab 4x4, and was thinking about getting a 5" suspension lift (Tuff Country) and 33x12.5's. Anyone with any thoughts on Tuff Country products and what issues I might have with a kit and tires this size?
Old 07-14-2004, 10:42 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Lift and tires question
You will have to change your gear ratio in your differentials to match the increased tire circumference. Otherwise you'll loose alot of torque.
Old 07-15-2004, 11:41 PM
Vroom2's Avatar
Vroom2 Vroom2 is offline
I've seen a few trucks with similar lifts - I think you'd be very pleased with Tuff Country's product. Brian is right on - you'll effectively be making your final drive ratio taller. If you're really after the look and ground clearance, I'd give it a shot before making the call on new gears.
Are you looking at aftermarket rims as well? The only issue I can think of is running 12.5" wide tires on stock 7" rims. If you're planning on sticking with the stock wheels, I'd run the question by your tire pro just to make sure.
Good luck!
Take care,
Jerry
Take care,
Jerry
'03 GMC Yukon Denali; www.suvworld.com/vroomvroom
'04 GMC Yukon Denali XL; www.suvworld.com/mrsvroom
'04 Toyota Tacoma XtraCab V6 4x4; www.toyotatruckworld.com/vroomvroom
