Old 07-14-2004, 10:00 PM
DrewR DrewR is offline
overheating and shaking problems
I just bought a 92 Camaro Z28 which has two problems: it is overheating and is shaking when I brake. The thermostat seems to be working and someone at an autoparts shop told me that it sounded like the air intake needs to be replaced. Any thoughts on this and shaking?
Old 07-14-2004, 10:03 PM
Dober89 Dober89 is offline
Re: overheating and shaking problems
I cant understand why the air intake would need to be replaced because of an overheating problem.
I would suggest checking around the rad near the bottom. Alot of times leaves and stuff can get stuck up in front of it. Also there should be a big plastic spoiler that sticks down just behind the rad to push up air. That can also cause overheating.
The shaking is most likely from warped brake rotors.
Old 07-14-2004, 10:08 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
possibly your tires are out of alignment or have some wierd wear too.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 07-14-2004, 10:11 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
alignment wont cause shaking. if there is pulsation in the pedal then the rotors are warped. if your steering wheel is shaking then the front wheels are out of balance. if your seat is shaking then its the rear wheels that need balancing.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 07-14-2004, 10:13 PM
korndogg's Avatar
welcome to the forum by the way
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 07-14-2004, 10:19 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
when does the car overheat??? sitting still or at speed??? or all the time???
id comment on the shaking, but its been covered quite well.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-14-2004, 10:23 PM
korndogg's Avatar
Re: Re: overheating and shaking problems
ahem....thank you ...thank you
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 07-14-2004, 10:28 PM
89IROC&RS's Avatar
lol, dont let it go to your head, im sure i could think of SOMETHING else to say on the subject
Old 07-14-2004, 10:48 PM
don't make him whip out the shop books...
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 07-14-2004, 10:50 PM
89IROC&RS's Avatar
lol, start quoting mic specs, and throw away thickness, out of round measurements, yadda yadda so on and so forth
Old 07-14-2004, 11:32 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Welcome to the Forum!
Overheating is pretty common in these cars but its also easy to avoid.. As mentioned, make sure your rad fins arent clogged up real bad, your air dam is still in place (underneath the car right infront of the rad) Let your car warm up to operating temp, and grab the upper and lower rad hoses.. If the upper hose is cool, and the lower hose is very hot.. chances are your thermostat isnt working.. Also grab the upper rad hose and squeeze it.. When you let go you should feel a surge of coolant going through.. This will tell you your water pump is workin OK!
Make sure your fans are coming on at proper temps, you could have a faulty fan switch or relay.. Check all your rad hoses, make sure they arent corroded or collapsed.. its fairly common..
Hope that helps
1991 Camaro Z28
Old 07-14-2004, 11:42 PM
My air dam is pretty scratched up from steep driveways and such, thats not too detrimental right?
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 07-14-2004, 11:53 PM
89IROC&RS's Avatar
naw, it only causes problems when it falls off completely and just to clarify for people, the air dam is not the chin spoiler its a black, flat, plastic peice, that bolts under the car, about a foot and a half back from the chin spoiler, under the radiator, to keep hot air from circulating back uunder the radiator.
Old 07-14-2004, 11:57 PM
i dont think its cracked but if it is should i worry about it? cuz it could be, it takes abuse around here
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 07-15-2004, 10:47 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
air damn also directs air up into the radiator, thats why they over heat on the highway without one...
