Old 07-14-2004, 05:08 PM
fordforlife's Avatar
fordforlife fordforlife is offline
how much does a 351 weigh?
i gotta pull my 351 out of my bronco (i was the one with bad piston rings and god knows what else) do i need a 1000lb engine stand or a 2000lb. the $ difference is $50, so if i can get by with the 1k, i would like too. thx!!!!
Old 07-14-2004, 08:09 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
The 1K will do ya fine. I pulled a 400 out of my friends truck with a 1 ton and another friend of mine put a 460 in a bronco with a 1 ton. Now if your lifting a diesel thats a different story.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-14-2004, 08:59 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: how much a 351 weighs
1 ton = 2000lbs
Old 07-14-2004, 09:12 PM
im renting an engine hoist, im talking about the stand to store it in my garage. 1000lbs or 2000lbs? its the kind where the engine bolts onto it.
Old 07-14-2004, 09:38 PM
Oops, I meant 1000lb on all that, not one ton.
Old 07-14-2004, 09:48 PM
351wStang's Avatar
The 1000lb engine stand should be more than plenty.
Old 07-14-2004, 10:48 PM
thx!!
