Old 07-14-2004, 04:49 PM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
Harmonic Balancer Removal
Im trying to get the Harmonic Balancer off my 94 z28, I have the pully off and the bolt in the center, i have the puller on and i got it as tight as i can get it.. ive even used an impact on it.. its starting to bent the puller itself. It just wont come off, what am i doing wrong. Ive tried hitting it with a hammer and everything.
Old 07-14-2004, 06:03 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Harmonic Balancer Removal
try some C4
Old 07-14-2004, 06:05 PM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
You'll have to make sure that you have the puller on there perfectly straight. That will make a lot of difference. I hope that helps.
Jake
Old 07-14-2004, 06:31 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
take out the bolt
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-14-2004, 06:57 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
lol.. thatd be a good start
1991 Camaro Z28
Old 07-14-2004, 08:47 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
try something like wd-40 or penetrating oil and let set for a few hours. and use a steering wheel puller instead of the standard 2 or 3 jaw puller.
Old 07-14-2004, 10:42 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
are you using a harmonic balencer puller or jaq kinda like 4 on floor said? i would use a balencer puller/steering wheel puller. they are comenly designed to do both. im asuming since you said you have the puller as tight as you can get it that you have the jaw type and i would say try the other kind. just like he said above.
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 07-15-2004, 03:47 PM
vettemaan's Avatar
vettemaan vettemaan is offline
Send a message via ICQ to vettemaan Send a message via AIM to vettemaan
make sure you are using the right tip, if it has multiple ones
