Old 07-14-2004, 04:19 PM
thizishkenny thizishkenny is offline
Send a message via AIM to thizishkenny
compound over decal
I was wondering after you put a decal on could you just use rubbing compound over it or do you have to clear coat then rub it. I'm at this point in my model but don't know what to do and btw it is a cf hood decal or supposed to be anyway.
Old 07-14-2004, 04:42 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
CF decals look better once you clearcoat them.
i dont think its a good idea to use rubbing compund over decals that arent clear coated, it is a harsh substance that will remove paint inorder to produce a perfect finsih,
you can use it before you put decals on, or after you clearcoat the decals
Old 07-14-2004, 05:03 PM
ProSStreet's Avatar
ProSStreet ProSStreet is offline
Re: compound over decal
i would definately clear it first, rubbing a bare decal is just asking for trouble
Old 07-14-2004, 05:19 PM
Oh ok thanks a lot for the help
Old 07-14-2004, 05:20 PM
primera man's Avatar
"P-Man"
Dont compound it...use wax if you dont want to clear coat them
View All My Models Here.
Old 07-14-2004, 06:09 PM
tcho1120 tcho1120 is offline
I'd recommend you to spray a coat of smoke color on the carbon fibre. I've learned it from another model forum and the result turned out great. it looks more realistic than just clearcoating it. hope it helps.
Old 07-14-2004, 07:02 PM
bvia's Avatar
bvia bvia is offline
Re: Re: compound over decal
I second what PDaddy says. Compounding over a bare, unprotected decal will simply remove the ink layers on the decal...If it's a metallic CF decal (i.e. SMS) you'll remove the dark top layer and end up with metallic streaks...
Carnuba wax is good for bare decals as is overcoating the CF decals with Johnson's Future/Kleer/Klere/Klare/howeveryaspeelitinyourcountry floor wax. You can always mix Tamiya Flat base (X-21?) to vary the amount of shine in the Future.
hth,
Bill
Old 07-15-2004, 02:17 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Many CF decals (like SMS) are much too bright- carbon fiber only looks that bright when illuminated by a strobe flash for photography. Toning them down by spraying something like Tamiya smoke gives them a much more scale appearence.
PHOTOBUCKET SUCKS
Old 07-15-2004, 02:31 PM
Vric's Avatar
Vric Vric is offline
I tryed it (coumpound over CF decal)
even if the decal didn't bend or anything, that don't give you anything. so just don't do it since it'S useless
