Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 07-14-2004, 02:34 PM
JettaLover1970 JettaLover1970 is offline
1996 jETTA SUNROOF MALFUNCTIONING
Guys I am having problems with my Jetta Wolfburg edition's sunroof. It stopped working and duno whether its the fuse or the motor thats malfunctioning. Can you suggest which fuse (number) should I check? Or what are the alternatives to fixing my problem other than spending $500?
Thanks!
Old 07-14-2004, 07:45 PM
boschmann boschmann is offline
Re: 1996 jETTA SUNROOF MALFUNCTIONING
Used motors at www.cat-part.com
Old 07-16-2004, 10:31 AM
CaptainLonewolf's Avatar
CaptainLonewolf CaptainLonewolf is offline
Send a message via AIM to CaptainLonewolf
Lightbulb Fuse Number...
I'm not sure that a fuse is the problem, but it's definitely worth a try to check. I wish I could tell you which number, but I can't seem to find any information on which fuse number could be for the sunroof. Your best bet, as much of a pain as it is, would be to check each fuse and see which one has blown, then replace it.
E-mail me if you need any more help!
___________________________
~Lonewolf~
"I live my life a quarter mile at a time; nothing else matters... for those ten seconds or less, I'm free..."
Old 07-27-2004, 07:52 AM
BluesCruiser BluesCruiser is offline
I read in the manual that if you pop off the light switch there is a small crank you can use to close and open it with mine is a 97 GL
BC
