Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 01-29-2002, 04:37 PM
[TWUBLE]'s Avatar
[TWUBLE] [TWUBLE] is offline
bleed valve
ok.. i know this has been said a MILLION times before... i think i pretty much know how to make one... but im not sure as to what to buy...
Can anyone tell me where to go in auckland and what to buy? cheers... coz im only boosting 10psi (installed the boost guage last night) and i want 13.5..
Also.... anyone who knows the mods on my car (3" trust exhaust, K&N, GAB Adjustable suspension, 17" mags, Remapped chip) what should i be launching from?
Cheers,
JP
Proud to be a member of the AF Kiwi Krew!
1 life, 1 licence, 1 day, Save it for the strip...
You cant begin to consider the palpable hate in the air when your near. - s|ipkn0t
Why do I have a conscious. All it does is fuck with me! - k0Rn
Old 01-30-2002, 06:59 PM
R33's Avatar
R33 R33 is offline
Send a message via Yahoo to R33
Red line my friend....red line!!
Hey, what are you doing in the fast lane?
Old 01-30-2002, 07:45 PM
[TWUBLE]'s Avatar
hahhaha i wish buddy i wish! not enuff traction to do that!!
Old 03-20-2002, 10:41 AM
NiteskyR's Avatar
NiteskyR NiteskyR is offline
Send a message via AIM to NiteskyR
bleed valve eh
this site tells u how to do it
http://www.autospeed.com/A_0685/page1.html
thats part 2 , do a search for part 1
Old 03-22-2002, 01:06 AM
KingNismo KingNismo is offline
Talking Jumping Point
:Badass: 3500RPM is always the basic starting point.
Old 04-13-2002, 05:20 AM
-Joel- -Joel- is offline
To get a more linear power curve and prevent spiking in the mid range and boost drop off in the top end instead of taking the wastegates source from the turbo take it from the plenium as there is a pressure drop over the std intercooler and piping.
I think you need somthing called a check valve but.. The GTIR's use this system i guess the R32's were just older technology then the R33 went straight the ECU controlled boost.
ok if that went over your head.
Usually when the wastegate sees that say 7psi has been reached, it reads that 7psi from directly in front of the turbo therefor by the time the air has passed through the intercooler and through the piping to the Inlet Plenium chamber there is a pressure drop.
Also with the stock IC it becomes a restiction over around 5000rpm that is why you will see a psi drop on your guage. By reading from the inlet plenium (where your guage does) you will make the turbo work just that little bit harder to hold the required psi as the volume of air at highrev's (consumption) will not be able to flow as quick enough compared to when the motor is at half rev's (consumes less)
Hope that makes sense ppls..
Get Used To It!
:monkeypis V8
Old 04-14-2002, 08:29 PM
rev210 rev210 is offline
Launching with traction is as easy as "launching with traction".
Rear wheel drive wise you would do well to bog it down off the start a little. Try 2000rpm clutch slip to give a smooth take off. On the stock turbo they boost as soon as 2300rpm so there is scant time to get rolling before power comes a knocking. The best strategy is to get rolling before stomping the gas pedal real hard.
Full boost launches are for guys with sticky rubber or 4wd, by full boost I mean 3500rpm or higher. Just rev as much as the rubber can hold on take off and no more. Wheel spin takes time to go away once started.
Old 04-15-2002, 04:32 AM
Try a 2000rpm clutch slip against an Auto V8 Commo...
I need to do a 3500rpm clutch slip any less and they kill you off the line.
Get Used To It!
:monkeypis V8
Old 06-19-2002, 10:57 PM
[TWUBLE]'s Avatar
Can you sort of explain in a bit more detail exactly how to plumb the bleed valve off the plenium rather thant he actuator line?
cheers,
JP
Old 06-20-2002, 12:46 AM
Simple.
Instead of running the hose from the wastegate actuator to the connector in front of the turbo run the hose to the plenium chamber.
You will however need or require a one way valve that will prevent vacuum from sucking through the bleed setup obviously. i.e the Brake booster has one of these check valves so when it is on boost air does not blow in to it.
Understand.
Get Used To It!
:monkeypis V8
Old 06-20-2002, 01:57 AM
[TWUBLE]'s Avatar
so your saying i should run my bleed valve line off the plenium chamber? or from the actuator to the plenium chamber? still kinda confused
Old 06-20-2002, 10:54 PM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
Me thinks he means run from the wastegate actuator to the plenium chamber... I think
And were in the hell have ya been bro!? Working on the wink wink in the nudge nudge? :silly2:
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 06-21-2002, 11:26 AM
[TWUBLE]'s Avatar
hrmmm... i still dont get it..
there is a tube coming off the actuator that goes somewhere (not sure) and my bleed valve is t'd off it... so he's saying i should run the bleeded end and bleed into my plenium rather than atmosphere?
nah bro... just been workng and shit havnt had a chance to get to a computer too
Old 06-21-2002, 02:09 PM
Gonthrax's Avatar
Skyline Guy
Yes... No... I'm not sure what the correct answer is, I can't see it so I have no clue
Ok... Follow the hose that comes off the actuator, find ot were it goes. If it goes infront of the turbo, cap off were it goes in and run it to your plenium. But you still have to put a check valve in there too... I think
Neishlin Motors
Old 06-21-2002, 08:27 PM
100% right Gonthrax.
<bashes head on table>
It is such a simple idea i can't understant how every 1 else can't understand?!?!?!
Get Used To It!
:monkeypis V8
