Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-14-2004, 09:03 AM
wolfewynd wolfewynd is offline
Angry 1987 dodge ram 150 LE
im having some trouble w/ the electrical problem w/ my dodge. It has a 318 ( v8 ) in it. I have replaced the starter,ignition switch,and starter relay w/ no avail and still wont start. I can start the truck when when i cross the starter seliond, but the only problem i have when i do that is the stater wont shut off after i do that. Any suggestions ??????????
thanx,
donald
Old 07-17-2004, 12:24 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 1987 dodge ram 150 LE
Dodge is notorious for eating ballast resistors. You should always carry spares.
My Mopars
Old 07-21-2004, 10:54 AM
praisethelowered's Avatar
praisethelowered praisethelowered is offline
Check the fuasable links going to the ignition switch. I had the same problem on my truck (same model and year), and one of the links (there's 4 at 1 junction coming off the battery) was blown. It looked ok at first (insulation was still intact), but the wire inside was completely blown. A quick check is to disconect the harness from the ignition switch, and check the leads going to the switch. 4 of the wires should be hot (12V), I forget which colors though. The colors should be the same as the fusable links. The links are on the inside of the driver's side fender.
Old 08-08-2004, 05:23 PM
vaughnone4 vaughnone4 is offline
thanx,
donald
I am having some what of the same problem with my 87 ram 150 with a 318 v8. The truck will start when it is cold without any problem but when it gets hot it will not start. I changed the statrer 3 times with no luck. I also change the starter relay but still having the same problem. Keep me posted if you get any good sugestion.
Old 08-11-2004, 10:31 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Bleed's right, replace the ballast resistor. (That's what I was thinking about on another post)
Old 04-02-2006, 08:06 PM
adrenalin2k4 adrenalin2k4 is offline
Where is the ballast resistor located at?
adrenalin
Old 04-03-2006, 07:23 AM
Adrenalin, check the date on the last post before you answer it...this thread had been dead for almost 2years!
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
