Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 07-14-2004, 08:57 AM
FieroBird FieroBird is offline
Unhappy Headlight Module Problem
Hey there, my first post,
I have a problem with the passenger side headlight module. When the lights are switched on, the left one works perfectly but the right one just pops up a little bit and just doesn't have the "oomph" to get up. The electric motor is ok , I think its some sort of gearing like the plastic gear is rotating on the metal etc etc.
Any solutions?
Old 07-14-2004, 11:46 AM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: Headlight Module Problem
Unless the module itself (or actuating rod) is bent, the motor assembly needs to be pulled apart and rebuilt or replaced. Might be bad internal electrical contacts or a gear starting to strip.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 07-14-2004, 04:47 PM
GTpaul86 GTpaul86 is offline
Send a message via AIM to GTpaul86
i HAVE a simular problem my driver side goes up just fine but it does not go down the motor is not spinning or anything it just does not go down till you push down or smack the motor the it kicks on and goes down fine i would like to know why mine does that i dont think it is a gear is there something wrong in the relay or what
Old 07-26-2004, 12:55 PM
russianyuri russianyuri is offline
Send a message via AIM to russianyuri
Its just one gear that is worn out or sticking. You can find a really cheap head light rebuild kit on ebay. I believe all you do is replace one gear and everything works perfect
