Old 07-14-2004, 09:19 AM
Ambo Ambo is offline
Question Suspension knowledge needed
Hey all. I'm looking to lower my car and have a friend who is going to do it for me. But I want to make sure that I am getting everything I need and this is where you guru's come in.
I have a 00 GT vert and am going to buy Eibach pro springs and Tokico struts. The Eibach springs are $200 on ebay new and the Tokico struts are $140 for the front, $70 for the rear. This will drop the car about 1.4".
Is this all I need? Are these parts worth the money? Am I missing anything? I'm open to changes and suggestions so those of you who have already lowered your stangs, please give your input.
Thanks!
Old 07-14-2004, 01:20 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Although not absolutely necessary, I would also invest in new offset rack bushings and (if they use em) rubber spring isolators. It might also be worth it, while the rears are off, to throw in some nice control arms to top it off.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-14-2004, 01:25 PM
fordforlife's Avatar
fordforlife fordforlife is offline
Re: Suspension knowledge needed
does he also need hotchkis (spelling?) camber plates?
Old 07-14-2004, 09:44 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
you only really need CC plates if you're running coilovers. they're designed to take the entire load of the front of the car, instead of the k-member taking it. and since the stock tower covers already have adjustments, there's really not point without coilovers.
but definitely get offset steering rack bushings, if you want your front tires to last at all. there's also issues with the bump geometry getting screwed up when lowering... usually this is compensated for with aftermarket k-members and control arms. no worries like this in the rear tho, it's just a solid axle. control arms would be nice tho, they really help with launching and ride height (if they're adjustable). adjustable upper arms are reccomended if you measure the pinion angle and it's off...
hope that helps
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
