Old 07-14-2004, 08:17 AM
geofroley geofroley is offline
Send a message via AIM to geofroley
Enamel primer
I'm using Model Masters enamel primer, but I get a small amount of orange peel. Is it because I'm using acrylics? I'm thinking about picking up some automotive primer.
Old 07-14-2004, 09:27 AM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
Re: Enamel primer
It might just be that Model Master Primer is not really in fact Primer. It is more of a off white paint. It doesnt sand like the tamiya primer. I would go for the automotive paint or tamiya surface primer.
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 07-14-2004, 08:24 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Enamel primer
Originally Posted by geofroley
I'm using Model Masters enamel primer... Is it because I'm using acrylics? ...
That doesnt make any sense, enamels and acrylics are two completely different types of paint.
-Mike
Old 07-14-2004, 08:38 PM
Re: Re: Enamel primer
The paint fumes are getting to him
Ferrari 360 Spider
Old 07-14-2004, 09:03 PM
935k3's Avatar
935k3 935k3 is offline
Enamel primer sounds like a true oxymoron. If you care about building good models do not use Testor's enamel primer. I would try their new laquer primer or use Tamiya,Duplicolor or Krylon. DO NOT USE TESTOR'S(ENAMEL) PRIMER!!!!! It's not really primer it's just satin paint. It does not sand properly.
Old 07-14-2004, 09:10 PM
I'm gonna switch to automotive primer. Anyone know what kind I should use?
Old 07-14-2004, 09:17 PM
935k3's Avatar
Re: Enamel primer
Duplicolor or Plasticote are the best, Krylon is ok too except it prbably takes a little more sanding, but it's very good when you have done allot of bodywork. One word of caution spray them all very lightly at first and build it up because if applied to wet it can attack the plastic.
Old 07-14-2004, 11:31 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
Re: Enamel primer
i use only dupli-color paints on my cars never had any problems
Old 07-14-2004, 11:35 PM
ProSStreet's Avatar
ProSStreet ProSStreet is offline
Re: Enamel primer
I use Plasti-kote Automotive sandable primer, never had any problems
Old 07-15-2004, 07:42 AM
I wont have to worry about that. I'm going to extract it from the can and spray it through my airbrush. Anyone know what I should use to clean out my airbrush after spaying the primer?
Old 07-15-2004, 09:03 AM
Vric's Avatar
Vric Vric is offline
Re: Enamel primer
It's normal
Modelmaster and Testor are the same paint. Testor Primer is the worst thing you can buy. You will never get a smooth surface and it's unsadable. Also, it take near 1 month to dry and will react with a lot of paint.
Stip it !
As for automotive, Duplicolor is lice (i tried there black one) but I stick with Tamiya White Primer for perfect result
Old 07-15-2004, 09:12 AM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
ive used Testors primer plenty of times and have come up with no problems. Then again all i use is testors paint so maybe thats why. It comes out smooth enough and takes to wetsanding...not very well but it DOES sand.
Old 07-15-2004, 09:13 AM
Originally Posted by Vric
It's normal
Stip it !
So your saying I should strip it?
Old 07-15-2004, 09:26 AM
Vric's Avatar
Re: Enamel primer
yes Strip it. If you use Acrylic primer or paint over it, the paint will crack
strip that primer, and put the spraycan in the garbage. Any other brand of primer will be better than Testor one
Old 07-15-2004, 09:30 AM
Thanks for the heads up Vric. I'll pick up some automotive primer at the hardware store later today.
