Old 07-14-2004, 01:23 AM
FastTrackToFreedom FastTrackToFreedom is offline
Two quick questions
Does anyone know where Ic an find a cast and camber correction kit for my 96 GSX? I can't keep the damn thing from wandering and it has been aligned 4 times by different shops to no avail.
Also, what do you guys think of the Evo 16G turbo? I was thinking bout replacing mine but I don't wanted get owned as far as emissions and legality.
Why should driving a sports car feel like operating a machine.......when it can feel like moving a muscle?
Old 07-14-2004, 07:29 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Two quick questions
What are the specs on the camber now? I Would go messing with it unless there is something seriosuly wrong. A camber kit actually made my car handle terribly.
EVO16G is a great turbo for 300-350 whp. Changing the turbo wont affect legality, but all the supporting mods can....
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-14-2004, 02:31 PM
Lol I don't really know what is wrong with it now, apparently my integra had the same problem and there was a kit out to correct the camber and cas which trued out the wandering.
My debate was beween the Evo 16G and the Garret Big T-28 what would you guys rather fo for?
Old 07-14-2004, 03:08 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
The evoIII 16g and the T-28 are about the same price, but the evoIII will take you further in terms of power/price! The evoIII 16g will also outflow the t-28 easily. I'd go with the evoIII 16g if I were you! Almost everyone agrees that the evoIII 16g is a GREAT turbo that has proven itself with dyno runs/track times over and over again!
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 07-14-2004, 06:11 PM
slowgsowner slowgsowner is offline
as far as your wandering problem is concerned, check all your bushings and ball joints, turn tires left check again, turn right and check again.
was your car ever in an accident? if I am not mistaken there was a recall on the ball joints.
Old 07-14-2004, 06:18 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
is your car lowered? if its a steering problem its probably tie rod ends. check your wheel bearings tie rod end and ball joints for play. just jack up one wheel at a time and try to shift the tire side to side, up and down, and try to turn it inward and outward(like what it does when you turn the steering wheel). it shouldnt move in any direction. if it moves up and down its usually balljoints. if it turns inward or outward its probably tie rod ends. if it shifts side to side check that your wheel bearings are tight. if you need any help checking the stuff pm me
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-14-2004, 06:25 PM
KevinE326 KevinE326 is offline
Camber Correction Kit and bushings kits.
http://www.roadraceengineering.com/eclsuspension.htm
Old 07-14-2004, 06:54 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
evo 16g all the way... t-28 is way overpriced...
