Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-14-2004, 12:04 AM
67ragtop 67ragtop is offline
96 Sierra 5.7 Error DTC P1351
I get a DTC code error P1351, IC Circuit High Voltage. The truck will sometimes stall when I first try to start it, without waiting I try again and it starts and runs fine. Once it stalls the egine light will come on with error P1351. This might happen a everyday or I could go a week with it starting on the first try. If the truck start on the first try for a few days the engine light will go off. I have replaced the coil and control module along with wires and plugs, and fuel pump. I was thinking of replacing the Crank Senor next??? Am I looking in the wrong area??
Old 07-15-2004, 02:43 AM
TweakedGM TweakedGM is offline
Re: 96 Sierra 5.7 Error DTC P1351
p1351 is open coil wire
p is powertrain, 1 is mfg , 3 is ignition system or misfiring.5 and 1 are faults
Old 07-29-2004, 03:28 PM
Replaced coil again, still have same problem and code. Could it be the control module?
Old 08-08-2004, 01:08 AM
did you replace the coil wire to
Old 08-10-2004, 11:00 PM
Yes, I replaced the coil and spark plug wires less then a year ago. I'm going to replace the cap and rotor. Don't know where else to look. Will let you know how I make out.
