Old 07-13-2004, 11:01 PM
Michael 1 Michael 1 is offline
2001 F250 Leaking diesel on right side of motor
Hi, I have a 2001 F250 with a 7.3L diesel. And it just has recently started leaking a little diesel on the right side of the motor. I noticed it when i changed the oil the other day. Has anyone else had this similar trouble? Let me know.
Thanks
Mike
Old 07-14-2004, 01:01 PM
ModMech's Avatar
ModMech ModMech is offline
Re: 2001 F250 Leaking diesel on right side of motor
The fuel drain valve on the filter housing is not shut off completely. I find this ALL the time.
Old 09-15-2004, 09:04 PM
jzeusjackson jzeusjackson is offline
Question Re: 2001 F250 Leaking diesel on right side of motor
Hello Micheal,,
Just wondering if you found out what the problem was. I seem to be having the same problem. Please advise.
Jaime
Old 12-07-2005, 09:49 AM
bryonr bryonr is offline
Same problem
My 99 is leaking diesel on the right side , the drain valve is closed and it is still leaking. It seems to leak more when I let it idle for more than 10 min. If I drive it it wont leak for a while. I am wondering if the valve is going bad. The truck has 400,000 on it. Any ideas
Old 12-14-2005, 12:08 PM
Rottweiler482 Rottweiler482 is offline
Hey I'm having the same exact problem, I have a 91 f250 w/ 7.3 Does anyone have and suggestions before i bring it in to Ford???
Thanks,
Jerry
Old 12-18-2005, 01:05 PM
ModMech's Avatar
Jerry,
Your ''91 has a different engine, same displacement, completely different design. You have a "lift pump" on the rt front side, and they are subject to leaks, as are the fitting seals, which are easily replaceable.
