Old 07-13-2004, 10:00 PM
tds715 tds715 is offline
Send a message via AIM to tds715
will a non aod c4 work in my 88
i need a new trans and this guy in my city has a c4 form his torino he wants 200 for it with the shift kit installed. wil it work?
what the diffrence between the aod and the non aod trans
94 accord in works h23 turbo full body kit and bit of shaving and new paint
88 gt 5.0 just gettin started
Old 07-14-2004, 12:06 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: will a non aod c4 work in my 88
AOD has 4 gears, C4 has 3. C4 does not have an overdrive, meaning its top gear(3rd gear) is a 1:1(or nearby) drive ratio. AOD does. As for will work, yes. If you have a 302 it will bolt up(and maybe even if you don't, not sure on non-v8 bellhousing patterns). You will need a c4 torque converter, and most likely a driveshaft(they're probably different lengths.) I think the trans crossmember/mount is the same for both c4 and aod, but not sure on that. You won't have OD, so your highway rpms will be higher, but it will work.
Old 07-14-2004, 12:13 AM
hmm not lookign for a new drivesfat so i may pass this up
Old 07-14-2004, 11:49 AM
burly94gt burly94gt is offline
dude just look in one thread up and there is plenty of info on that...
God said RWD, and all the little torque lovers of the world said, AMEN!!
