Old 07-13-2004, 09:05 PM
Arsenik111 Arsenik111 is offline
Neutral Droping
can u damage your transmission or anything else if you put your car in drive from neutral with the gas down?
Old 07-14-2004, 02:05 AM
mixedbreedx mixedbreedx is offline
Banned
yes, I was told it would be better to put it in drive and hold the brake while gassing it (without spinning the tires) then when you're to go let off the brake and floor it.
Old 07-14-2004, 02:08 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: Neutral Droping
YES, the answer is YES! dont do it.
power brake it if you wanna squeal the tires or take off fast, but if the tires dont break loose, I wouldnt hold that too long either.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 07-17-2004, 07:47 PM
Maifirehawk Maifirehawk is offline
Re: Neutral Droping
If you keep doing " Neutral Drop" like that, the first thing you will tosted is your Forward Clutch, ones it tosed it will take out your 3rd Clutch and Input Sprag, all three of these packed together in your Forward Drum,
Mai
Old 07-17-2004, 11:59 PM
wierdoslam wierdoslam is offline
Re: Neutral Droping
I've managed to break the drum that the input shaft splines into while driving (Stage 2 shift kit in a 350at), so doing neutral drops from a stop will place your trans at even more risk. You don't want to have to hang your head in shame, like I had to after finally getting that Miata to give up the fast lane.
Old 07-21-2004, 01:29 AM
SphinXX SphinXX is offline
Banned
Point being, if you can't burn out without tranny dropping it or power braking it, then you shouldn't be showing off cause your car isn't fast.
Old 08-11-2004, 07:56 PM
Cor1580 Cor1580 is offline
Nuetral droppin huh? I used to have a 95 3.4 camaro. I was 17 at the time. Was on the cruise strip at the time and Did the drop. All i heard was the spinning of someting other than my tires. I thought i dropped the tranny. Towed it home and saw that the midshift bearing and where the two driveshafts met had now been a nicely shaped slick surface. ordered the light weight shaft from RK sport. 700 later. So not a good idea. Stick with the power brakin or just dont try at all.
