Old 07-13-2004, 08:41 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Odometer not working
Bought a 95 eagle talon with a non-working odometer. I know, you guys are going to tell me I shouldnt have bought it blah blah blah, but I know how many miles the car has. (Did lots-o-research). Anywho, I need to fix it.
I dont exactly know what the problem is, but I should just be able to unscrew the 2 screws on the cluster and take it out, right? I'm hopinh this is just a loose wire, but what else can the problem be? Thanks
Old 07-13-2004, 09:27 PM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
Re: Odometer not working
well at least it shows you are not putting on miles
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 07-14-2004, 10:32 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I know on the eclipse the odometer is electronic and can be "turned off" by pulling a fuse. The problem is that you loose your power windows, speedo, tach, etc. So it could be a fuse, but I don't know about the talon.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-14-2004, 12:28 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
try checking over the tranny you have a connector, that one is the one that tells you how fast are you running check if it's plugged if it's, try changing it cause maybe is bad, other thing you can do is check the cable of the odometer
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 07-14-2004, 09:03 PM
david-b's Avatar
Dave is THAT guy
I dont have power windows, but everything else (tach) is working fine. Just the odometer and the trip-miles doesnt work. Ill have to check the thingy on the tranny tomorrow. It seems like the tach wouldnt work then neither, but ill check.
I am going to take out the cluster later this week and check the wires. I hope this is easy to do.
I cant see how many M.P.G. im gettting... lmao :-)
Thanks.
Dave
Old 07-19-2004, 08:07 PM
david-b's Avatar
Dave is THAT guy
The lil piece on the tranny (the only one I could see) was already replaced by me. That tells the backups lights to turn on when in reverse.
I did try pulling out the cluster and check that. However, the cluster didnt seem to want to come all the way out. all the plastic connecters seemed fine. It's just simple plugins. They all looked good tho.
Another question: The dome lights and the light around the key-starter thingy no longer work at all. That could be a fuse, right? What fuse can that be? I didnt see any blown out.
Old 07-19-2004, 08:23 PM
GSTRacerNVUS GSTRacerNVUS is offline
The real big manual (I think its a hanes) shows what all the fuses do and where they are. I know that there's one online, but I don't remember the address. Its somewhere within the archives of this forum.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
