Old 07-13-2004, 07:49 PM
motorcycleman320 motorcycleman320 is offline
gen1engine swap in gen2
We are in the process of swapping a gen 1 motor into a gen2 gst. The motor is in and kinda running. The only thing gen1 is the block and cam angle sensor everything else is gen 2. We sliced the wires of the crank sensor to the cam angle sensor together. When we start the car up it runs for a second, but then fouls out, but if we unhook the mass air flow sensor it runs fine but a little rich. If anybody has any ideas how to fix this I would greatly appreciate it. Thanks, Harley
Old 07-13-2004, 09:26 PM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
Re: gen1engine swap in gen2
http://www.roadraceengineering.com/2...torinstall.htm
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
Old 07-13-2004, 10:54 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
www.magnusmotorsports.com
Old 07-14-2004, 07:40 AM
kjewer1 kjewer1 is offline
AF - Advisor
There is also a 1gina2g yahoogroup, that may be your best bet. I'm not sure I understand the problem, so I cant help. Of all the 6 bolt swaps I've done, I've never had a problem.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-14-2004, 02:08 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
did you try to adjust the timing with the CAS? (cam angle sensor)
Old 07-16-2004, 12:24 AM
Yes we tried adjusting the cas. It ran better but then when we raised the rpms to 2000 it stuck there so we moved it back. I will look at all the posted urls and maybe I can figure it out. Its probably something easy that was just overlooked. I will keep you guys posted. Thanks for the help. Harley
Old 07-16-2004, 07:40 AM
AF - Advisor
In any case you should use a timing light to set base timing with the CAS to 5 degrees. How you tell the ECU to stop interfering with base timing so you can set it depends on the year of the car.
Kevin Jewer
Old 07-18-2004, 06:21 PM
We called magnum motorsports and the guy there said that b/c of all the symptoms he thinks that we have a vacuum leak somewhere since the bov wont release. Ill keep you guys updated.
