Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-13-2004, 06:44 PM
guru97 guru97 is offline
1997 jetta gt Hesitations
Noticed at first a hesitation about once a week , now it more like almost every time I drive it.
This is how it gos: the hesitation comes after my car is idle at a stop. When i press the gas pedal it seems like it doesnt want to go, seems to stay in neutral and if you push the gas pedal to much it gives you a hard kick. So the way I do it is that I dont press the gas pedal real slow and it doesnt give me to much trouble except the cars behind honk. I noticed this in gears 1 to 3 especially up tp 3000 rpm's.
I had a tune up done, changed rotar cap, plugs, wiring etc and the problem persists. I am helpless.
Old 07-14-2004, 07:49 PM
boschmann boschmann is offline
Re: 1997 jetta gt Hesitations
Is this automatic? Does it feel like the transmission might be slipping? When was the fuel filter last changed? I've seen dirty fuel injectors cause this, you might want to take it to someone who can properly check out the fuel system to chck this as they are a bit pricey.
Old 07-14-2004, 09:51 PM
No i have a manual trans. I last changed the feul filter about a month ago. After my tune up it was fine for about a week then the problem continued.
Maybe transmission fuel is low? How much to check the fuel system? could it be the mass air flow sensor? Vaccuum line?
Old 07-15-2004, 05:15 PM
It could be alot of things. Is the check engine light on.
Old 07-15-2004, 05:48 PM
Re: Re: 1997 jetta gt Hesitations
No engine light comes on. How am I supposed to know what it is and get it fixed?
Old 07-15-2004, 05:49 PM
Also very noticeable when I wash my car and drive it. The hesitation or lack of power is more evident.
Old 07-15-2004, 05:51 PM
So by process of elemination, what do u think it could be from the gathered info?
Old 07-16-2004, 03:41 PM
Well, the water thing throws the ignition coil into suspicion. It's located on the firewall, just follow the center wire from the distributor cap. Spray it with water & see if it starts acring & sputtering.
Old 07-17-2004, 04:47 PM
Tried the spray water and everything seems normal. Now what?
Old 07-18-2004, 08:06 PM
You can also spray the plug wires & distributor cap. Pull the wires from the ignition coil & distributor cap and look for burning of the metal wire ends and pins on the cap.
Old 07-19-2004, 04:12 PM
I also noticed that when I leave my car outdoors and its hot and sunny all day, the hesitations i feel them from the moment I start the car and its pretty bad.
Old 07-24-2004, 08:20 PM
95vwvr6 95vwvr6 is offline
yeah I'm having the same problem with my 95 vr6...my sensor is on too and i think it might have something to do with the emmissions.
Old 07-24-2004, 08:30 PM
Guru, is this a 2.0 or VR6?
Old 07-25-2004, 04:41 PM
this is a 2.0 97 jetta Gt
Old 07-25-2004, 04:49 PM
what sensor are you talking about 95vwvr6?
