View Poll Results: Is it safe to remove my thermostat? I live in texas where the coldest it gets its 60.
yes 0 0%
no 5 100.00%
Voters: 5. You may not vote on this poll
Old 07-13-2004, 04:16 PM
89TX5.0 89TX5.0 is offline
thermostat
Is it safe to take my thermostat on an 89 mustang (5.0). I do live in Texas so it only gets 60 like in the winter maybe 5 or 6 times. It doesnt really get colder than that?
Old 07-13-2004, 05:22 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: thermostat
Taking your thermostat out will not make your car run cooler. I will however more than likely make it overheat. Be removing the thermostat you remove a restriction in your coolant flow which was put there for a reason. If your coolant circulates too fast it will be rushed out of the radiator before it has time to cool. Therefore leading to an overheating problem. NEVER take your thermostat out!
What do you hope to gain by the way, by removing your thermostat?
Old 07-13-2004, 05:48 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: thermostat
What he said. Go to an advance auto and get a 160 degree thermostat. Stant PN 45356
Then drill a 1/8" hole about 1/8" from the edge and make sure it is installed at the top of the t-stat.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 07-13-2004, 07:27 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
NO NO NO! No 160 or 180 or whatever. Use a stock replacement 192 - 195. The engine is designed to run at that temp for optimal fuel economy and horsepower.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-13-2004, 08:14 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: thermostat
Please refer to your other thread about over heating.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-14-2004, 09:14 AM
Re: thermostat
Yes that's true, but down here with a 180 the engine stays over 200 degrees. Mine will run between 220-230 on most days with a 180 T-stat, I don't want to think about how hot it would get with a 192.
Hopefully a combination of a fluidyne rad and a 160 will get me in the 190's.
Freedom Isn't Free.
Old 07-14-2004, 09:40 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
if you are running any higher compression than stock or, a turbo or blower, I would go with a 160* thermostat. If it is stock compression and NA, I would not go any colder than 180. If you have a 180 degree thermostat and you run between 200-235, you need a new raidator/fan controll. 235 is just to damn hot for any engine. Things will always stay together longer when they are colder over beting hotter.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 07-14-2004, 12:13 PM
Re: thermostat
My compression is up about a point from stock, and yes I need to be much much cooler than I am, that's why I ordered the fluidyne rad. My fan also doesn't kick on low speed until just over 200 degrees (factory bs).
Ford actually designed all its fuel injected vehicles to run over 200 degrees to "reduce emissions". Everyone who knows anything about engines knows this is bad for performance, hence the ready availability of the 180 and 160 t-stats. The factory 192 was designed to let the motor get over 200. The reason I say 160 is in Texas heat even with a cooling system in good shape, a 180 is hard pressed to keep the motor in the 190's.
Freedom Isn't Free.
Old 07-14-2004, 01:26 PM
thnx for all the opionions it was greatly appreciated!
Old 07-14-2004, 02:50 PM
HiFlow5 0's Avatar
Stanger
Re: Re: thermostat
160 is still too damn cold. Your going to be running too rich. I have a 192* stat, and my temp stays at 192, and I have yet to see it go over 200. Something's wrong with your cooling system if your running a lot hotter then the stat being used. Again, you will get better cooling capabilities when a warmer stat, 160 doesn't let the coolant dissipate heat long enough, and you will also be playing games with the ECU.
-2013 Ford Flex
-1999 Ford F150
