Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-13-2004, 01:43 PM
exitpexit exitpexit is offline
Send a message via AIM to exitpexit
help diagnosing problem
i have a 90 integra with over 200k miles on it. After having the car sit out in the hot sun (temp was 100+) i drove it for about 10 minutes at an average of 80mph and when i came to a stop the car just shut off. then without trying to restart it, i pressed on the accelerator and it started up again. At the next stop it shut off again, then it stopped doing that, what could be wrong ? it usually has a rough idle, but now the tach displays a bouncing needle. do i have to replace some sensors ? i appreciate the help.
Old 07-13-2004, 10:21 PM
DoMeStiC_kila DoMeStiC_kila is offline
hard to say.... take a look at your ignition coil, you may have a weak or intermittent spark. you might also want to check your pcv(positive crankcase ventilation) valve and idle air control valve because of your rough idle but i doubt thats it. you can always by a new car too....
Total bouts: 61, KO: 37, W: 19, L: 4, KO'd: 1 -Muhammad (the greatest) Ali
Old 07-14-2004, 11:49 AM
CapoCrimini CapoCrimini is offline
Send a message via AIM to CapoCrimini Send a message via MSN to CapoCrimini Send a message via Yahoo to CapoCrimini
Hmm
hm, you'll need to explain a bit more..
Could be a clogged air filter, some electric loose electric connection or a thousand other things.
When it stops, does the engine kinda "hesitates" before stopping or does it shut down instantaneously ?
Old 07-14-2004, 02:21 PM
Re: help diagnosing problem
ya, when the engine stops it just shuts down, there's no sort of hesitation.
