Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-13-2004, 01:34 PM
Fleainat Fleainat is offline
Question Oil light?
A month ago I had my 100K mile maintanence.
4 days ago I checked my oil and it was about 1cm below the lower line on the dipstick, and I added oil.
A couple days ago I just noticed that my oil light is on while I start my engine every time. It turns off once the engine is completely started. Is the light supposed to be on this long, or is it supposed to turn off the instant I turn the key to start? Thanks. btw, I have a 97 SH
Old 07-13-2004, 02:04 PM
km23honda's Avatar
km23honda km23honda is offline
Send a message via AIM to km23honda Send a message via MSN to km23honda Send a message via Yahoo to km23honda
Re: Oil light?
I believe that is normal i have that same thing. Just when you start the car my oil light is one and then after the starter stops it truns off. I have a 92 si. and going to 170,000 miles still very stong running.
1992 Honda Prelude SI
Old 07-13-2004, 04:35 PM
joellthomas joellthomas is offline
the oil light should go off after the engine starts, when the oil pump developes enough pressure. the oil pump is driven by the engine turning.
Old 07-13-2004, 05:01 PM
More info: I noticed that the light is on for about one second (after the engine starts). But, if the car was already running, and a RE-start, the light doesn't stay on at all after I start.
Old 07-13-2004, 05:14 PM
i'll watch mine, but one second is ok. was a different oil filter put on when service was done, some oil filters may take a little longer to build oil pressure.
Old 07-13-2004, 06:42 PM
yea there was but i've already driven 3000 miles in the last month so time for a new one already
Old 09-10-2004, 05:09 PM
juju juju is offline
Re: Oil light?
HELP !! I have 1989 preldue and the oil light will not go off. Change oil & Filter . And also did an flush, but the light stays on Help!!!!!!
Old 09-10-2004, 05:12 PM
Re: Oil light?
oil pressure sender might keep the light on???
Old 09-11-2004, 10:58 AM
Re: Oil light?
replace the sensor or check oil pressure at the sensor port with an oil pressure guage. you can check for voltage at the sensor, but i'm not know if it would be on/off as with a switch or varies with oil pressure. it should make some kind of change.
