Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-13-2004, 01:58 PM
Jcvaz Jcvaz is offline
Exclamation 97 problems with ignition
Hello everyone,
when i start my car in the morning as i turn the key i get clicks. everything else turns on radio, lights etc. Eventually the car starts what do you guys think this could be? and would it be something i can do myself?
Thank you,
JC
Old 07-13-2004, 02:12 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: 97 problems with ignition
You might need to check the battery. Also, you may need to clean the posts and the terminals. If this don't work, you may need to replace the battery, or replace the terminals. Before replacing the battery, run it on a charger. Most chargers have a 40 AMP start feature, which allows you to switch the charger over to that and try to start the vehicle. If the vehicle starts, then it's the battery.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 07-13-2004, 03:24 PM
Thank You Chief I will try that and let you know.
Old 07-13-2004, 04:28 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
If it only clicks once each time you turn the key, it is the starter contacts. If there are many clicks each time the key is turned, then it is a power problem (battery, battery terminal connection quality, cables, ground connection quality, starter terminals, etc).
Old 07-14-2004, 12:43 AM
vchid vchid is offline
Try the most likely ones first like the other posts have suggested - batteries etc. I had a similar problem once and it turned out that I was leaking oil onto the neutral switch. somehow that was causing some kind of communication problem. I was always able to put it in neutral and start the car though. I think the neutral switch stops you from starting in gear so it would always start when in neutral.
