Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 07-13-2004, 11:22 AM
bcopeland bcopeland is offline
Automatic Tranmission Service
I was advised by my dealership that if you change the transmission fluid after 140,000 miles and it has never been changed before that you will have transmission problems. Is this true? Also, I was advised that a fluid flush takes care of needing a filter. Is that also true? I was always taught that you should change the filter when changing fluid. Please advise. Thanks.
Old 07-13-2004, 11:29 AM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
Yes, changing the fluid at high miles can be an issue if never changed. Inspect the color of the fluid, it should be a reddish, clearish, pinkish color. IF it has never been changed than it is thin, and brown. Metal fillings can build up in this fluid and when the fluid is changed it floods the transmission. That is what happened to a family members car. The easiest flush that some places do is where they circulate new fluid through the transmission. The force of the fluid through the trans removes particles from the filter. Old fluid is completely flushed out while new fluid remains. Nothing is removed or changed besides the fluid when this is done. I had this done and it works well. I had this done in my prelude at 28,000 miles. Hope this helps
Old 07-13-2004, 11:31 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Automatic Tranmission Service
This is a tough one...
More times then most, If a customer has never seviced the trans and then decides to do it at a high mileage, most likely it will be back within a couple weeks for repairs....especially with a flush.
believe it or not, the particles suspended in the old fluid is the only thing keeping the trans in working order...flushing the trans and replacing the filter cleans out these suspended particles and the trans will begin to slip...
For proper operation, your trans should be serviced at the intervals specified by the manufactor.
Proper maintenance will keep everything in proper operating order.
Personally I am not a big fan of trans flushes especially after about 80k.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 07-13-2004, 06:17 PM
denalio34ceo denalio34ceo is offline
Engine flushes and transmission flushes are another way to squeeze money out of you. Mechanics know it and the dealers know it. Flushes are bad news.
Old 07-14-2004, 10:46 AM
Engine flushes may be a waste of money but tranmission flushes on auto transmissions are worth it if the car has it changed regulary. Black thin transmission fluid cannot be good. The fluid breaks down over time and cannot withstand the heat. Regular changes every 20,000 -30,000 add to the longetivity of the trans.
Old 07-16-2004, 06:02 AM
pinnacle pinnacle is offline
I would like to hear from you trans guys. See my post on 7/10/04. subject- Transmission Fluid Change posted by - pinnacle
Thanks
Old 07-20-2004, 07:58 AM
Under what category?
Old 04-06-2005, 10:04 PM
LOBSENZA LOBSENZA is offline
I am planning to change the transmission fluid in my 2001 Yukon XL Denali and wanted to use full synthetic fluid. Which brand(s) do you recommend? I am planning to drop the pan for the fluid change and change the filter. I know this only changes a portion of the fluid. Will it hurt to mix synthetic with what they put in at the factory?
