Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 07-13-2004, 07:12 AM
dgadgetman dgadgetman is offline
A/C Problem 1990 Pickup
Last summer I converted over to 134 refrigerant and replaced everything except the compressor on my 4x4. It has the 22re engine, 5 speed and it blows icicles when its above idle, but at idle it blows only warm to hot air. Has anyone had this happen, or know a solution?
Old 07-13-2004, 10:58 AM
gator2764 gator2764 is offline
Is the electric fan running while at idle? The A/C system needs air blowing across it to work properly.
Old 07-13-2004, 12:19 PM
Re: A/C Problem 1990 Pickup
Yes the fan works fine. It only blows warm air when it is at idle. The system shows that it is fully charged with refrigerant.
Old 07-13-2004, 03:19 PM
Re: Re: A/C Problem 1990 Pickup
The only way to know for sure if it is fully charged is to have the 134 vacumed all of the way out and have the correct amount (example of 1.75 pounds) pumped back in. If you know someone at a shop who is a really good friend have him do that.
Old 07-13-2004, 03:40 PM
Re: Re: Re: A/C Problem 1990 Pickup
That was done the first time and they checked it last week and it showing a good charge.
Old 12-12-2004, 06:27 PM
skinneep skinneep is offline
Re: Re: Re: Re: A/C Problem 1990 Pickup
I have a 90 22-r truck. I have not converted over, but I have the exact same problem. Very cold when driving, but in idle I hear the compressor kick off. I have been told the same thing about the charge as well. But mine was fine. The other thing you can look into is the voltage that the a/c clutch is getting. I am sorry if I am a little vague with the info. But I was told something along those lines. I tried replacing the idle air control valve and that did not fix the problem. Hope I have been of some help.
