Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-13-2004, 12:21 AM
michaelnac michaelnac is offline
Engine cranks, but doesn't start
Hi,
I have a 1993 Integra LS, 159k miles AT. For the last couple weeks I had troubles with starting the car. In the process I have replaced the starter, and the distributor. The battery, spark plugs, and wires are good. It seems like it doesn't want to start after I drive the car for couple hours(stop and go). Today i had troubles again. The engine would crank, but wouldn't start. After 10 minutes it did start, but the S3(auto sport shift) light was flashing. when I drove the car seemed like it was running on only three cylinders(very weak). I drove it a little, then stopped, after 5 minutes it started and ran just fine. My head gasket is leaking a little, could that cause the problem?, flooded engine?, I'm thinking it might be the fuel pump? any thoughts? I don't want to keep throwing money on more parts without knowing the cause...
Michael.
Old 07-13-2004, 08:18 AM
abrammicah abrammicah is offline
Re: Engine cranks, but doesn't start
I had a similar issue once, but I just bought a new motor all together. I know you don't want to do that...I wish I hadn't. I was told that it was a bad head gasket. I was also told, by another source, that there's no way it was a head gasket. Maybe fix the gasket, since you know it's bad, and see if that does it. My other guess would have been the same as yours...fuel pump. Good luck man.
Old 07-13-2004, 09:19 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
hmm, are you loosing coolant? is it overheating?
If you know the head gasket is bad I would start there. that can cause major problems down the line.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 07-13-2004, 11:33 AM
integralover's Avatar
integralover integralover is offline
i would deffinately start with the head gasket. if it is bad you could be leaking coolant, oil, or loosing compression in that one cylinder. i don't think its the fuel pumps fault. get that gasket replaced
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 07-14-2004, 12:17 AM
Replaced the valve cover gasket today, hopefully solves the problem. No problems starting the car, yet...
Old 07-14-2004, 03:23 AM
valve cover gasket or head gasket? the valve cover gasket won't give you those problems. if you have any questions on how to do the head gasket just ask. i have done three of them, and know a few tricks to make it easier.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 07-16-2004, 11:35 AM
Thumbs up
I think the ECU is the problem. When the car does start it doesn't run on 3 cylinders as i thought. The AT shifts into 4th gear right away, and stays there until i restart the car(that's why it feels so weak). The ECU is what controls the transmission, and it probably doesn't send spark when i try to start it. I read on carpoint.com that ecu is a common problem for 1990-1992 integras. mine is 1993 but was produced October 1992. So I bought a used ECU with 90,000 miles from an 93 AT teg of ebay for 50$.
Michael.
Old 07-18-2004, 02:22 AM
let us know how it goes.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
