Old 07-13-2004, 01:10 AM
Future303 Future303 is offline
Where's the damn computer on my '95 Stang??
I bought a SuperChip that has to be installed in the PCM Slot of the Computer. I know it's supposed to be on the Passenger front side. All I see there is the glove compartment, and a plastic piece that is covering what looks like an airbag of some sort.
Am I missing something?
Old 07-13-2004, 09:25 AM
Wolf's Avatar
Wolf Wolf is offline
Send a message via AIM to Wolf
Re: Where's the damn computer on my '95 Stang??
On the foxbodies, it's behind the plastic kick panel, near the passenger's feet. Don't know about the SN95s, but it'd be the place to start looking.
Old 07-13-2004, 10:07 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Same place
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 07-20-2004, 01:29 AM
Ok, I found what I think is the computer, it's a black box that is right under the glove compartment.
Anybody have any clue how to remove this thing???
Old 07-20-2004, 04:46 AM
Wolf's Avatar
Re: Re: Where's the damn computer on my '95 Stang??
Unplug the wire harness, and there's a hex bolt holding it to the wall(?)
Old 07-20-2004, 11:14 PM
jcook249 jcook249 is offline
Post Re: It turns over but no spark '95 Stang??
I have a 95 stang I was going down the road the other day and the motor just stoped. It's not getting any spark so I changed the coil and still it don't start then I changed the control module and still nothing I checked all the fuses and thay are good. It turns over but no spark. Can anybody help?
Old 07-20-2004, 11:55 PM
eillob's Avatar
eillob eillob is offline
Ahh that does not sound like you found your computer. The computer is a silver rectanangular box and it is not under the glove box. The computer is located on the passenger side down by the floor. If you are sitting in your passenger seat there is a plastic panel just to the right of your right foot. The carpet runs underneath it. You need to take off the long plastic piece next to the seat in order to get that panel off. Once off the computer sits behind 3 wire harnessess. You'll have to wrestle with it a little to get it out. There is a 10mm bolt that goes through the harness and holds the harness and computer together. You may have to unbolt it in order to get the computer out because there isn't much play. Make sure you disconnect the negative side of you battery before you start.
To give you a better idea of where it is. Its behind your front passenger wheel, but still inside the vehicle. Hope that helps.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
