Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-12-2004, 10:40 PM
lance280zx lance280zx is offline
idle speed too high sometimes
my 1981 280zx 5 spd manual non turbo car normally idles at 900 rpm or so. but sometime the idle will go up to 1500 or 2000 rpm.
I do not see anything obvious restricting the throttle linkage from returning all the way back to idle. there is some sort of leak at the idle speed screw. if i cover the hole that the screw is in with my finger the hissing sound stops. is there supposed to be a leakage here? What other devices should I investigate to lower the idle speed?
Old 07-13-2004, 09:38 AM
icice9's Avatar
icice9 icice9 is offline
Send a message via AIM to icice9
Re: idle speed too high sometimes
the cause of your high idle is the vacuumme leak. fix that and check your TPS as well.
