Old 07-12-2004, 09:35 PM
nates6969 nates6969 is offline
question about fuel pump
Hey I was wondering if anyone know for sure if the fuel pump is supposed to turn on as soon as the key is set to the ON position on a 91 or around that Talon/eclipse or laser. Mine only turns on when onthe start position and i think this is causing my car to die after started
Old 07-13-2004, 12:45 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: question about fuel pump
On DSMs the pump only runs while there is a signal from the cam angle sensor, so it will come on as soon as you start to crank the motor over. ITs builds pressure instantly, so this is not likely the cause of your problem.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
