Go Back   Automotive Forums Car Chat > Cars in General
Old 07-12-2004, 09:41 PM
NeonAtron NeonAtron is offline
Question Underbody Lights Question
1988 Tercel Q.
Old 07-12-2004, 09:45 PM
Re: Underbody Lights Question
I have a 1988 Toyota Tercel and i want to put some undercar lights on it: but the way the front bumper is shaped it looks like the actual bulb will be shown and thats illegal where i stay. Does anybody have any suggestions on how to fix this problem? Thanx.
Old 07-14-2004, 05:11 AM
thunderchicken2 thunderchicken2 is offline
My only suggestion would be a body kit/ground effects.
Old 07-14-2004, 05:16 PM
Vinny03 Vinny03 is offline
Send a message via AIM to Vinny03
ok well streetglow is very easy to install. if i were u i wud find a spot the u can drill mounts and do it that way. they dont have to be on the bumber.
Old 07-14-2004, 07:05 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
dig deeper into that bumper , bet you it will fit like a glove in a good spot , take a look at all the undercarriage plastic thats in the way and let me know what you find
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 07-14-2004, 07:57 PM
RADMANX RADMANX is offline
I think your best option is to sell your piece of shit toyota tercel, and buy a real car.. Then, dont waste money on piece of shit underglow. Do you think your tercel is going to win a car show?
Like i always say, "I live my life a 1/4 mile at a time, and for those 19 seconds or more, i wish i was boosted..."
2000 Honda Civic EX
Just starting...
Old 07-15-2004, 02:14 PM
ive seen plenty of hot tercells beat ferraris and other hot cars in races as well as shows. but the minimum budget to that is about 25 grand
Old 07-15-2004, 02:28 PM
Different people like different cars , please dont go into a thread and spam it up ok radmanx ty keep your negatives away unless theres a poll allowing you too.
Old 09-27-2004, 01:17 PM
Passivality Passivality is offline
Send a message via AIM to Passivality
word, well, i would sugest going to your local hardware store, buying some mesh grill, and putting it on the front of the light so that you see meshgrill instead of the actual light, problem solved. you would only need it to be an inch long at that, and i know at the local home depot, they have entire sheets for 7.89 if you look around for a while, its all near the wood and crap.
Old 09-28-2004, 09:16 AM
The way his front bumper is set and the space is so tight there was only one place he could put the light and that was inside the bumper out of view the only way you could tell the light is there was to have them on at night (neonatron showed me a pic of the bumper) but if he was to put the grill mesh in then it would fishnet shadows or whatever pattern the mesh is and would glow real nice on the pavement that was a nice tip to finish off neonatrons tercel. The mesh your reffering to from the hardware store is called burn barrel mesh and its great to use as a mesh grill more heavy duty than whats available for autos (they use flimsy girly crap) but is tougher to cut with side cutters. I put 5 inserts in my grill and 2 on my hood for under 10 bucks. I found the burn barrel mesh near the wood like passivality said and it was rusty as heck. I use hydrophoric acid to eat the rust away used a ph balanced car soap to nuetralize it then I rust primed it and painted it. You can use bonding glue , tie straps , bolts or screws to hold it in place. I used construction bonding cement it tacks and dries quick and is cheaper than automotive bonding glue.
Im not sure if neonatron wants a mesh tho , I guess we will find out.
Old 09-30-2004, 09:50 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
i used to have a 1987 tercel 4wd, i started a community for them at: www.tercel4wd.com
if you look on cardomain there's a tercel with a neon tube in the front of the bumper, where the plastic grille is. There are a number of rubber parts on the bottom of the car that you may not need anymore, but when i still had the car i looked under and there was lots of space up front and around back to put under car lighting, but i'm not too sure about the sidez. I bet you can ghetto rig it somehow. Heck, i had to ghetto rig everything in that car since there's absolutely no aftermarket for it now except for oem parts.
Also, if you got an ugly colored interior i suggest giving it a spruced up paint job. Those cars last forever man, take care of it : p
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 10-05-2004, 09:58 AM
Under the car is a lip that follows around a foot from each side that lip is a great place for side neon/Led tubes to be placed just put it in the high spot so If you bottom out it bottoms out on the body not the lights.
