Old 07-12-2004, 08:09 PM
anthony90si anthony90si is offline
si tranny
i am changing my si engin and tranny bacially cause the tranny is blown. and i have a b18b kicking round. while everthing is out would it be worth to put in a si tranny with the b18. or just stick with the b18 tranny
Old 07-12-2004, 08:14 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you are talking about your stock civc d series si tranny then it wont bolt up to your b18 engine. stick with the b18 tranny
you should search on what is needed to swap in a b series into the 4th gen
Team Lonely Drivers
Old 07-14-2004, 03:36 AM
dssmax's Avatar
dssmax dssmax is offline
Re: si tranny
Yea,
I have a b18b1 along with the rest of the teg that I got from a my uncle and I have no clue what I'm going to do with it... I meen it seems that putting it in to my Civic looks like more trouble then its worth. (The Teg is totaled but only on one corner on the front with a smash going down the middle of the car to the back so I can't fix it and run it.)
I wish I had a B16A1...
Oh yea, stay with the stock tranny you will have less problems setting it up, or at least thats the consensus from what I have read as I as well wanted to do a motor and tranny swap.
MAX
Old 07-14-2004, 03:48 AM
GTA's Avatar
GTA GTA is offline
Whee..
Re: si tranny
si tranny wont fit on a b-series engine.
and Dssmax, its just as hard to put in a b16a1 as it is a b18b1...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-14-2004, 10:45 AM
dssmax's Avatar
Re: Re: si tranny
Wow Really? I thought that because it was a OBD-0 (b16a1) that would make it eaiser... Then it would be all about the mounts and you don't have to really worry about the wiring just run the wire for the vtec.
MAX
Old 07-14-2004, 01:10 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: si tranny
you can run a b18b1 as a b18a1 so it can be obd0.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 07-14-2004, 05:07 PM
Re: si tranny
just use a computer from a 90-91 teg thats my plan cause the b18a i got is from a 92
