Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-12-2004, 07:42 PM
bikecop bikecop is offline
need help antifreeze leak
Just changed out my thermostat on me 97 4.0 sohc and now I have a water leak coming from somewhere in the area. Any one else had any problems with the thermostat housing>
Old 07-12-2004, 10:47 PM
XLT03 XLT03 is offline
Re: need help antifreeze leak
Did you replace the seal around the thermostat? If no, replace with new one. Also did you remove radiator hose from thermostat housing before removing housing to get to thermostat? If yes, you probably did not tighten the hose clamp enough.
Old 07-13-2004, 11:59 AM
ishop4less ishop4less is offline
Yes, I Agree with XLT03, make sure you clean it as well before put the seal back. BTW: when you mention that you have a water leak from somewhere in the area, are you talking about in the thermostat housing area or somewhere else?
