Old 07-12-2004, 07:47 PM
altij altij is offline
Angry Noise
I had a problem that got fix really fast,thanks for the help i got here.Now i have another question:when car is on park or moving slow and i turn wheels,makes noise that you can feel on steering wheel,could this be the steering pump?and if its,is this hard to fix?Is louder when car or wheater is cold!
Old 07-12-2004, 09:42 PM
catback23 catback23 is offline
Re: Noise
Does it feel like the tires rubbing the surface their on? Check you power steering fluid level, it might be low. If it sounds like squealing your power steering pump belt might be too loose. These are my ideas but personally from experience I'm going with the latter.
Old 07-12-2004, 09:55 PM
Re: Noise
Tires not rubbing,fluid level its ok,how do you adjust the belt?because it sound like squealing,like i said its louder when car is cold and it gets hard on the steering wheel ,but just when turning wheels!thanks
Old 07-13-2004, 07:18 PM
Re: Noise
To adjust the belt your going to have to find the pulley that loosens and tightens that belt and adjust the pulley so the belt is tight but not tight enough to be a guitar string. If you can't find the pulley and don't have a repair manual for your car you can use autozone.com's online repair guide/manual, it's basically just an online version of a chilton book for your car or truck.
Old 07-13-2004, 11:06 PM
Re: Noise
I will look into autozone,i have the haynes manual but is confusing.Today i spray some belt dressing and sound got quieter,and it didnt make noise on turns,does that mean belt is loose or tight?By the way,thanks for your help catback23
