Old 07-12-2004, 06:26 PM
strawsy strawsy is offline
Keeps blowing, need some help
I just got my new system, built my own box. I have 2 kicker s12l7s and a hifonics bx1500d. The subs are in a big ported box. but my problem is i keep blowing fuses the amp is 4 guage thats what power wire i have, the inline fuse is whats blowing it was originally 80 but it keeps blowing those, i dont know if theres a bigger fuse i can get or what but somethings wrong....everything is hooked up good. If someone knows what their doing please help me theres nothing worse than having a $1400 dollar system and it not work.
Old 07-12-2004, 06:31 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you have a short somewhere on your 12v powerline ... or your amp's power supply is bad.
Old 07-12-2004, 06:34 PM
Re: Keeps blowing, need some help
ok what is the 12v powerline, and how would my amps power supply be bad. If it is one of these how would i check to make sure and what would i do. thanks for taking the time to reply
Old 07-12-2004, 06:43 PM
you kinda have me worried now, your not saying my amp is bad are you?? cause i just bought it
Old 07-14-2004, 10:06 PM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
the thick cable that connects your battery to your amp is your 12v powerline. re-check that entire cable run, and make sure the only exposed wire is on the ends where they have solid connections. if you have a voltmeter built into your dash check that your output voltage is between 10-17vdc, because current (amps) is directly proportional to voltage. more volts = more amps, and if it exceeds your fuse rating it'll blow. if you need to, use a stand alone meter to gauge your output voltage.
THE DARKNESS!!!
an African Soup Bone Production...
