Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 07-12-2004, 04:39 PM
dweigand dweigand is offline
Send a message via AIM to dweigand
Transmission problems
Hey guys. I got an 89 MX-6 GT and lately I've been having a lot of trouble with what I believe is the transmission. 3rd gear recently started not wanting to work, it's real hard to get it into 3rd most of the time like it just doesn't wanna go at all. I've been keeping an eye out at junkyards for tranmissions. Is there a diff. between the turbo and non-turbo tranny? Cuz I wouldn't wanna make the mistake of putting a weak one into a turbo and blowin that to shit. My friend and I checked my trans. oil level and it was extremely low so I added oil but it still runs like crap. I don't know what to do here other than just replace it. If anyone else has had this problem and can offer any advice, it would be greatly appreciated. Also, if anyone has replaced a trans. themselves and can offer any tips on doing that, I will probably be doing that shortly...thanks guys.
Old 07-12-2004, 05:52 PM
mx3man's Avatar
mx3man mx3man is offline
Send a message via MSN to mx3man
Re: Transmission problems
no there is no difference in tranny from the trubo or not... it is prolly a syncro or two that are fried.
Good luck changing the tranny yourself.. hope you have an engine lift. :/
Old 08-14-2004, 11:17 PM
mx6rrr's Avatar
mx6rrr mx6rrr is offline
when you check your tranny oil level, make sure you run the car for a while and shift/move through all gears...has to be check while hot. also, is your car an auto or manual, im guessing that it is a manual so...does the clutch move smoothly? the clutch could be bad if it doesnt. but if it is just one gear, yah, it probley is the tranny. i would have it checked out before you just go buy something though cause it could be something else.
Keep the rubber side down
Old 11-01-2004, 08:46 PM
badazzrx7 badazzrx7 is offline
look for tranny from gt 626 and turbo probes there all inter changable the non turbo and turbo trannys are differant the turbo are beefer.
