Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 07-12-2004, 03:46 PM
flsurf420 flsurf420 is offline
Send a message via AIM to flsurf420
Deville Draining Battery
Well, this problem has been going on for the past few days. The battery dies overnight. Last night put a older fully charged battery in, ran like a champ. Then come this morning had to jump start the car. It runs fine so the alternator might not be a significant problem. But my grandmother had an older cadillac that would have the same problem. She finally took it to the shop and it was a fuse or something. so the mechanic jerry-rigged a switch to turn off the power to that part.( oyea i think it was for the power antenna, because that broke, so i guess it would waste battery trying to move it up and down.) my car also has the power antenna but newer GM radio so maybe, the antenna is broke also?
Too many hobbies, not enough time or money!
Old 07-12-2004, 05:44 PM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
Re: Deville Draining Battery
Go to the antenna motor which is right under the antenna and unplug everything from it. Since it doesnt work why have it hooked up? If that doesnt work then it might be something else that stays on. On my merceds I took out the radio and somehow it kept draining the mattery even though the power wire wasnt hooked upto anything. I took the fuse out for the radio now its fine.
Old 07-12-2004, 06:24 PM
yea i was just told he thinks it was already unplugged. is there a quick way to check the fuses? and which draws the most power, during the OFF period.
Old 07-13-2004, 09:07 AM
took it to autozone, they tested the battery, it was a bad battery and would not hold a charge. so you think i should buy a new one and that will be a start if not solution to fixing the car. lol a dead battery, what a waste of time. why is it always something stupid, or right in front of you.
Old 07-13-2004, 05:04 PM
Antiburn's Avatar
Because the stupid things are always the problem, or the hardest to do. I say just buy some cheap-o battery and see if that fixes the problem. If not I would still check if the ant-ina is pluged in. The fuses are under your steering where where your feet go (I think, thats how it is on my car) You can take a flashlight and shine it up there and see them. But if you really want to inspect them take needle-nose pliers and pull each one out. Just remember where it goes.
Old 07-14-2004, 06:39 PM
might as well spend it on a good battery right. because either way i need one. i might put a nice system in there one day. so i want the extra power. how many cold cranking amps do i need as a minimum?
Old 07-18-2004, 06:22 PM
got a recycled battery from interstate for 20 bucks and it runs like a champ. starts every time. hopefully i fixed the problem. Thanks for the help everyone its greatly appreciated.
