Old 01-29-2002, 09:03 AM
duckhead4life duckhead4life is offline
Send a message via Yahoo to duckhead4life
Question help with neon lights in the interior
this is what i want to do i have four 6 inch neon lights and i am going to put them all in the interior. two under the dash and two under the front seat. i want to hook them up to the dome light. so that when i open my doors they come on and also when i hit the switch on my doom light. so what i need to know is how do i get those trim pieces off that lead to the room. what i am talking about are those trim pieces by the windows and also which wire do i use. does the doom light wire put out enough juice to run four neon lights are am i going to have to hook the up to something else. i really need help on this one. so any help would greatly be appreciated, thanks in advance i know that you all will come through for me you always have in the past.
drive it like you stole it or dont drive it at all
Old 01-29-2002, 11:26 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
one the dome light fuse would blow out everytime you turned them on, the circuit cant hold that much, you can however hook up a higher power fuse to the circuit but thats not recommended.
Unfortunatly i dont know how to remove the panels although im sure its just a few screws or soemthing, but a fellow 6th gener will assist you.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-29-2002, 11:37 AM
so since my fuse would blow how am i going to hook these lighs up and get the desired effects that i wont.
Old 01-29-2002, 04:45 PM
According2Me According2Me is offline
You can drive in Alaska? :sun:
Holla back youngin...
Old 01-29-2002, 06:44 PM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
Id say wire them to a switch and put the switch next to your light switch so then you can turn both of them on when you want.
Old 01-30-2002, 08:45 AM
of course you can drive in alaska. my car is very low to the ground to. low enough that if i went any lower my stock rims would rub. when i hit a bump. but back to what i was saying. there is noone out there who knows how to wire these lights into the dome light switch.
Old 01-30-2002, 12:46 PM
mAtC's Avatar
mAtC mAtC is offline
Send a message via AIM to mAtC
you actually could run those four neons off that circuit but they will be extremely faint(spreading the 10/15/20 watts out over 5 items). I recommend doing the fuse-bus-thing-off-the-battery (thus garunteed full strength with some exceptions) to the dome switch and splicing it to the lead wire. They most difficult part - if you are concerned with appearance - is hiding the wire to the dome light.
------------------------------------> [email protected]
Check out my huge civic gallery at http://matc_civic.tripod.com
And hopefully, another one when I get more time.
PureHONDA.com vetern since January 2000
Old 01-31-2002, 09:43 AM
hey man it sounds like a plan but could you go into more detail about what you are talking about. fuse-bus thing. tell me where i have to hook the wires up too. and everything
Old 01-31-2002, 05:05 PM
OisinT's Avatar
OisinT OisinT is offline
Banned
Send a message via AIM to OisinT
not the doom light!
ahhhhhhhhhhhhhhhhhhhhhhhhhh
gawd I love being a smartass
Old 01-31-2002, 07:44 PM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
you could use a relay i believe. no need of huge draw from dome light circuits but you can then run power wire to the neons and have the relay turn them on for you...
Old 02-01-2002, 01:26 AM
xivera's Avatar
xivera xivera is offline
Thumbs up Nice idea... It's like courtesy lights!
Why tap all the way at the dome light!?
Just tap the power wire of the lights to a wht/red wire leading to the dome light!
YOUR HOMEWORK: This wht/red wire splits into 2 wht/red wires from the under-hood fuse/relay box. (1 going to the dome light and the other going to the trunk light) You will need to access the one going to the dome light. Find it!
Also, pls. use an inline fuse at each tap. I'll leave the mounting of the neon lights to your discretion.
NOTE: Although I have referred to my Helm's SERVICE manual, I have never done this myself. (I never thought about it) I do not know where to access the red/wire. (Sorry... )
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 02-01-2002, 08:40 AM
where do i get this relay from. can i pick one up from the local napa. and is it called just a relay or some other fancy name.
Old 02-01-2002, 12:14 PM
igo4bmx's Avatar
Banned
do u have a radioshack?
Old 02-01-2002, 06:02 PM
yes there is a radio shack up here
Old 02-04-2002, 12:27 AM
ACCORDLVR ACCORDLVR is offline
no offense to anyone who posted here but it sounds like unqualified b.s. to me. 1st off neon lights which house their own transformer like the 4 -6" ones you have, have a minute amperage draw. ones that small generally consume about .01-.03 volts to run. do the math: your stock overhead (dome) light draws about 6-8 watts, with a peak of 10 watts when it's turned on. that's roughly .7 volts. you won't blow your fuses my man. what you need to do to do this is as follows:
remove your dome light assembly, pop off the plastic cover and there will be 2 small scews. disconnect it from the wiring harness. remove your headliner (so that you can run the wires to the neon) or you can feed the wire through with a home made feeder. mount your neons in the locations you choose and connect all for in parallell. (positive to positive, negative to negative. connect them all to your feed wire in the same manner. once you get done, to connect the feed wire to your overhead light all you have to do is use 2 quick splice connectors to the appropriate wires, use a light tester to find the positive, the other is the negative. do not re-insert the bulb (only because it will look dumb with neons and a bright light) re-assemble your housing and attach the connector and your home grown lighting project is done.
sorry if i sounded like an ass earlier to everyone else, but truth be told...i was just trying to give him the straight scoop.
"Bad cop! No doughnut!"
S.O.S. Help With Neon NFarran 1st Gen 95-99 7 08-14-2007 05:40 AM
silver Escalade with neon lights HittenSwitches WIP - Street 6 12-05-2005 07:26 AM
need help with neons!! beatpf Exterior | bodykits | Lighting 3 08-08-2004 07:25 PM
problem with neon lights 93rollaracer Cars in General 4 04-28-2004 12:19 PM
please help,can i change the interior lights? benie '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-12-2003 11:35 PM
