Old 07-12-2004, 11:49 AM
crsride86 crsride86 is offline
Angry my car pops why??
i have a 1986 ford mustang gt 5.0 it has a gt 40 302 high output with about 435 horse power..I cant get it to accelerate smooth it pops at about 2800 RPMS in every gear and i cannot get it to go past 4500 RPMS ..It is really annoying... I have put lots of money into this car to try to fix this problem. I changed the cam-feul preasure regulator- 50 millalitters throtle body larger feul rails...you would think it has to be something simple because the engine and 4 speed tran with all the other parts are all BRAND NEW. if anyone has had this problem or may know how i can fix this please help...any advice will help (i hope)
Old 07-12-2004, 12:23 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: my car pops why??
Need more info, what's your timing set at? Are you still speed-density or converted to mass-air? If you have 435 hp you have changed almost everything in that engine, so what's on it? What size injectors?
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 07-12-2004, 02:11 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Popping is usually a sign of detonation. Is it only under deccelartion, or all around? What grade fuel are you running and what's your timing set too? Any other info you could give would be good.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-14-2004, 06:25 PM
Re: Re: my car pops why??
im not sure what other information you need nut this i can give you ...the fuel preasure regulator is90lb...and the timing is set at 10
degrees advanced...if you need any other information please let me know and i will gladly give it to you....thanks soooo such
Old 07-14-2004, 06:30 PM
HiFlow5 0's Avatar
Stanger
Wen you say fuel pressure regulator is 90lbs, what do you mean? Stock fuel pressure is 38-39lbs. Also when does it pop? Under acceleration, decceleration, etc?
-2013 Ford Flex
-1999 Ford F150
Old 07-14-2004, 07:05 PM
i replaced the feul presure regulator to a holley high performance regulator 30 lb- 90 lbs adjustable..i have it set to 77.. i dont know the size of my injecters...it pops under acceleration at about 2800rpms..no back firing just spittin and sputtering...
Old 07-14-2004, 08:04 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Holy Shit! Lower that fuel pressure now! Set it to no more than 40 psi! Go....Cmon. Then post back with results!
What color are the injectors?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-14-2004, 09:15 PM
cheap5.0 cheap5.0 is offline
WOW, i guess we know what happens when your fuel pressure is too high, now don't we?
1993 Grand-Am GT...SOLD!
1982 VW Rabbit.......SOLD!
1988 Cavalier..........SOLD!
1989 Mustang GT 5spSOLD!
2002 Celica GT-S 6spSOLD!
2005 Jeep GC, 5.7 HEMI, heated leather and Alpine goodys
Old 07-22-2004, 03:36 PM
ok i changed the fuel psi to a verious pounds of psi the car runs better with it set at 47psi i played with the timing still popping but runs better. the oil psi has always been way low but sence changed the timing to 14 advanced the oil psi has been better but still not the way it should be. i cant get the car to go any faster then 130-140 mph, the rpms are only at 3200. i have changed so many things that i dont know what else it could be. the car popps while accerating in gear or in nutural . i want to feel the cars full power and i have yet to , any other info you could give would be most helpful..i've done everything you said to do so far and its got better but it still not running to its full potential THANKS
Old 07-22-2004, 03:49 PM
Just a quick question..i was reading some of the topics and saw that there was video you could download, Is there any on mustang 5.0 ? if so please let me know where i could find it! THANKS
