850 EML Light
About once per day and after driving on the interstate for five minutes, the EML light comes on. Engine quickly starts losing power meaning you have to jump to the shoulder. To fix, turn the engine off, wait 5 seconds for the light to go off, and restart. It will not come on again that day. Sometimes the light will go two weeks before coming on again. Usually it happens every day or two.
Re: 850 EML Light
there can be a number of causes and you mentioned NO 'check engine' lamp warning it sounds like a failing EML Control Unit, I've seen this symptom before. try and get both the DME's and the EML faults surveyed and see what turns up.
Re: 850 EML Light
Jeffrey, Thanks! No check engine lamp. The computer shows the EML code. My mechanic thinks it could be a low voltage issue. Maybe old batteries. He says usually the EML will not reset so easily when bad. However, it is very strange that the EML comes on at about the same location on the highway each time (after about 5 minutes). It may do it every day and then not happen for 15 days. I thought moisture could be involved. Confused on this... New EML is about $1,000
Re: 850 EML Light
they're expensive! ! yes. your technician should be able to read out the EML fault codes. he shouldn't have to think here [though it's an excellent practice
a majority of the time], he needs what information the EML system can give him 1st. IF he can't access it you'll need to find someone who can. Best to you and your tech...............................jb. |
Re: 850 EML Light
Re: Re: 850 EML Light
Thanks, Jim |
Re: 850 EML Light
Cleaning the DK's is a nice idea, but it won't fix your problem........won't hurt it either.
Re: Re: Re: 850 EML Light
DO NOT buy a new EML unit. They are very robust and unless someone has played with it (re-chipping is common), I wouldn't replace it just yet!. Quick test: See which bank is running (left or right - pop the bonnet, you'll know straight away). Get home and swap DK's. I will eat my hat if the dead side doesn't change which will prove that 1 DK is dirty. Again, save yourself the cash, do the DK's... I'll eat my hat if that doesn't fix your problem. And DON'T BUY new DK's. A lot of mechanics will tell you that they are not serviceable - they are and after a good clean, end up good as new. If I do end up eating my hat check fuel filters then fuel pumps (both) then fuel pressure regulators then intake manifold gaskets (in that order) - but I really don't think it will get to that.Oh, what's your mileage? If it's 80-100k miles DK's
Help !!! I bought my 850 just a few weeks ago and its been fine. I came back the other night and there was black ice all over the driveway - nearly hit the house, but ABS and traction control were working overtime and saved me..... The EML light kicked in as I was trying to move it across the very slippery ice. But now the EML light comes on when I start the car and its going nowhere... I was told the computer was replaced a year or so ago, but its clearly the ABS/TCS activity that has caused this. I assume it needs resetting. Any ideas ?
Re: 850 EML Light
Hi RedV8,
ACS and EML are directly linked: FYI, ASC will command the EML controller to roll back the throttle if wheelspin continues after retarding the ignition. They're linked via a command line from the ASC to the EML. A pulse width modulated signal indicates to the EML how much the throttle should be closed. There could be numerous reasons why the EML light is on. Faulty wheel speed sensor Low battery voltage (can throw up errors) Start driving and flick the ASC switch a few times. The EML light might go off. (note: ASC light on means you have turned it off). or You could go to a dealer and get a MODIC dump of the EML which will show what the error is. or Disconnect battery for 30 minutes or so may reset it - (WARNING) - doing this might fix the problem but you will have to resync your windows, sunroof DK throttles and you will need the code to unlock your radio. |
Hi,
on my BMW850I the EML indicator sometime turn on and the engine loose power... should I clean the DM ? but... what is the DM? where is it and how do I clean id? thank you for your help Stefano |
:screwy: I JUST GOT A 850I AND THE TRANSMISSION WENT.
I DIDNT USE THE CAR FOR EVEN 1 DAY AND BOOM. I HAVE LOOKED AROUND AT OTHER PROBLES THAT PEOPLE SEEM TO HAVE ON THERE 850,S ( WHAT OTHER PROBLEMS DO YOU THINK WILL POP UP) ^ Last edited by taxi; 07-06-2005 at 12:39 PM. |
