Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 07-12-2004, 01:34 AM
mike5721947 mike5721947 is offline
Send a message via AIM to mike5721947 Send a message via MSN to mike5721947
bulged fenders?lifts?
ok i am wanting to get a ranger to convert to a street legel offroad racer(poser) for now until i get my complete licence (dont want to start all over) but am looking for bulged fenders and lift kits and what are a good year to do a offroad racer from?
i am wanting sites for offroad parts(lifts bulged fenders hoods etc...)
this is for research so i can see the posablities of the ranger.
Old 07-13-2004, 01:36 PM
TheRangerOfDanger TheRangerOfDanger is offline
first off, don't get a 1998 or newer. I made this mistake. Don't get me wrong, it is a wonderful truck and a stellar performer, but is a pain in the a** to lift. That is when Ford started with the independent front suspension, and a lift for it is very expensive - a 4" from superlift is like $1500 and 6" from other companies is even more. You can lift an earlier model for like $400... Also, go for a v-6 version, and you will be able to find many engine and drivetrain mods, although i have seen a few more for the 4.0 liter than the 3.0 (and fewer yet, though still plenty, for the 2.9). Check out www.therangerstation.com for anything else you want to know - check out under the "exterior" section for bulged fenders- (especially budget lifting), www.ford-trucks.com for general info, and http://ranger.racenet.net for a crap load of goodies (lifts, polyurethane, performance, and looks). Drop a line if you got more questions. A ranger is a good choice (good gas milege, good looks, many affordable parts, lots of support, and lots of oppurtunity for improvement (ie v8 swap))
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD40.
Old 07-13-2004, 03:43 PM
Re: bulged fenders?lifts?
cant find bulged fender for rangers anywhere in the links you gave me. are there any others?
Old 07-13-2004, 11:15 PM
http://www.off-road.com/prerocker/front_fe.html
http://www.therangerstation.com/Fiberglass.html
look at these under "fenders" and "fiberglass" - that's were it is
Old 07-14-2004, 05:53 PM
what is the largest flare and raise i can get?
i am wanting a mean tough looking apperence.
what about the largest flare and raise on the rear (short bed 93-97)
Old 07-14-2004, 06:49 PM
with that year model, the options are endless....
For bulged fenders, i would guess you could gain as much 6" unless you want to make your own stuff. If you check out Bushwacker flares, they are screw on and will go as much as 5" (much cheaper)
For the lift, you can get at least 6"-8" from a kit, or do a home made (I've seen a home made with like 15") but a kit is the best way to go. Another good thing about this truck is that is has the TTB (Twin Traction Beam) suspension that get a lot of extra wheel travel
Here's a good link for starters http://www.therangerstation.com/Suspension_Kits.html
Old 07-14-2004, 07:21 PM
i ment by raies and flare of the fenders not a lift i am probalbly get a stock wrecked ranger and redo the wrecked parts while puttimg on the fenders but leave the truck at stock ride hight until later with the larger fender flares would i be able to put 33x10" tire in there with stock hight but with no rubbing or bottoming out?
Old 07-15-2004, 10:58 PM
yeah, a 33x10 would be just right for a truck w/ stock suspension and flared (fiberglass) panels - you would still have plenty of space for wheel travel, and the tires wouldn't stick out, but you MAY need to get a litle extra backspacing on the rim...not sure
Old 07-16-2004, 11:54 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
i have a 2000 and with the 3" body lift i got 33x12.5's on 8" rims with 3&5/16ths backspaceing not to hit.only prob is by rear of front fender it's close but not hitting.
Old 07-17-2004, 11:08 PM
when you go to buy rims, how do you know how much backspacing they have? Or do you have a few choices? I've been thinking about getting some wider rims, but haven't seen backspacing numbers listed...
Old 07-18-2004, 11:30 AM
2000mudder's Avatar
check out www.summitracing.com. they have everything including links to manufactures sites.
Old 07-19-2004, 10:21 AM
sweetness.... thanks
Old 09-20-2005, 01:37 AM
wow, its been over a year! i ended up getting a 1986 olds cutlass ciera from my dad (going to sell it as im wanting a pickup.)
im still looking at the ranger and am wondering about the 1980-1992 rangers and prices for lifts.
mainly wanting something i can drive around town but have the clearence for offroad trails. (4-6") on therangerstation.com the skyjacker lifts are "recomended" is there anything else needed for the lifts?
also what tires can i safely clear with a skyjacker 4" lift? and a 6" lift?
EX-Owner of a grey 1986 Oldsmobile Cutlass Ciera Brougham
its gone towards the kidney foundation car autions.
EX-Owner of a blue 1991 pontiac firefly turbo
Now own a 1990 suzuki sidekick 3" lift, 235 A/T's winch bumper, and way to many km's.
also a beater hyundai pony from way back in 1985
Old 09-20-2005, 08:20 PM
it depends on the lift, but usually has everything except the optional stuff (Tires, rims, gears) - I would suggest getting a new pitman arm if you lift and the kit doesn't include one
Here is the hot link
Tire Fitment
