Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 01-29-2002, 04:09 AM
32godzilla 32godzilla is offline
RB20det injectors
Anyone know how big they are and the estimated limits for them? :bandit:
Old 01-29-2002, 12:29 PM
Forsteen Forsteen is offline
What to you mean estimated limits? The RB20DET injectors I believe are 270 cc. You can upgrade to 550cc if you get a better fuel pump and retune your ecu.
"I wash my hands of those who imagine chattering to be knowledge, silence to be ignorance, and affection to be art." Kahlil Gibran
http://www.skyline-racing-tech.com
Old 01-30-2002, 04:03 AM
Sorry, I meant like when do they need to be upgraded. Some people have told me that they are good for 300hp at the wheels. At 270cc i'd say they should be right? Any ideas?
Old 01-30-2002, 05:16 AM
I am about pushing about 270 HP with no problems with stock injectors. I don't know the limits of them though. I will be upgrading to 550 here soon.
Old 01-30-2002, 05:24 AM
yeah, i'm after the ones on the series 4 rx-7 but they seem to be hard to get in brisbane
Old 01-31-2002, 12:33 AM
Any ideas on how much i should pay for 6 x 550cc injectors?
Old 04-13-2002, 05:26 AM
-Joel- -Joel- is offline
Tilbrooks in Adelaide have pushed the RB20DET standard injectors to 220rwkw using a HKS GT2530.
To get this they used a Highpressure fuel pump and an adj. rising reg. fuel pressure reg. They then re-mapped the ecu to suit.
This is the absolute max they said they were able to get out of the std injectors.
Some ppls may say BULL $#@! but image a turbo pumping more pressure through allows you to squeeze more air in through the Inlet Valves for the duration the same is with the Injectors..
The duration for when they are open you are able to squeeze more fuel through with a higher PSI fuel pressure..
You need to get the ECU remapped or use a fuel comp but.
I think the Std. AFM maxes out at around 180rwkw.
But if you are going to the trouble of getting 220rwkw from the std injectors you would already need a remapped ecu or fuel comp. so with the remapped ecu or fuel comp you are able to fit a Z32 AFM and tune to suit.
Get Used To It!
:monkeypis V8
Old 04-14-2002, 08:33 PM
GTS-4 Ben's Avatar
GTS-4 Ben GTS-4 Ben is offline
Send a message via ICQ to GTS-4 Ben
Most injectors no matter the size are around $250-300NZ each new.
SDU Southland Moderator
Old 04-15-2002, 04:28 AM
Ben
Would you know if using large injectors actually affects the fuel atomisation?
.... erm..
What I mean by that is will it not spray as well under light throttle causing reduced economy and drivability?
Get Used To It!
:monkeypis V8
Old 04-15-2002, 05:33 AM
GTS-4 Ben's Avatar
I am pretty sure it does effect it.
Your are better off to have more rather than larger if the situation allows.
Look at Reece. 6 720cc's and 6 440cc's. HE could have gone 6 1000+ cc... but it would be very hard to get the car to run right...
Big injectors can cause alot of crap, thats why you need to get the right size. Same goes with anything, Too big a turbo, too big a Intercooler all can be bad...
Old 03-04-2004, 11:28 AM
Ismail Ismail is offline
Re: RB20det injectors
hi guys i want to know how i can retune my ecu rb20dett
Old 03-09-2004, 05:40 AM
You actually put two turbines on an RB20? Why? I don't think three cylinders puts out enough to be efficient. I've never seen this before and I've been here in Japan for over 3 years and in all the magazines I've looked at.
Old 03-09-2004, 06:22 PM
Derby's Avatar
Derby Derby is offline
Send a message via MSN to Derby
rb20, thats a 2 litre right.
so 1l for three cilinders. you live in japan right? Never seen a Charade turbo? 990 cc 3 cil. turbo.
IN europe we got a Smart. a 660cc 3 cil turbo. pushing 55kw, that is not much. but there are turbo's for 500 cc also. So there will be no prob with finding a suitable turbo. The HKS 2530 will not work obviously...
Derby
If there was one tiny little thing other then the rest, imagine the power it would have.
Is an RB20DET engine legal Anthony714 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 08-07-2010 05:36 PM
2003 Mustang GT - Injectors & MAF?? ndean52 Performance 1 05-03-2010 11:26 AM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
rb20det rb20det rb20det intake manifold skyline rb26dett style e30rb Cars/Parts for Sale/Exchange 1 11-19-2004 03:24 PM
