| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
superchargers are load dependant?
I had an argue with someone on this board, (not saying any names), he kept insisting and explaining how a supercharger (roots, centrifugal) IS load dependant, he said that if I were to stick my car in neutral and rev it up high, there will be little to NO boost.
According to what I have learned, I always thought they were RPM dependant because since it is connected to the the crankshaft of the engine, it wouldn't matter how much load there is, just how many RPMs there are. I will post his message in my next post. |
Re: superchargers are load dependant?
C'mon, isn't there ANYONE?
Superchargers isn't load dependant, but of course the throttle must be wide open if we want to see any boost in the plenum.
So, in order to make boost when the car isn't in gear, I MUST floor the throttle?
Does the message above even make sense to you? Cuz I sure don't got much clues on it. |
I'm don't get the part about "nowhere for the air to go" either. It's true that you probably won't get any boost while in neutral, because most supercharger clutches are linked to your neutral positon/clutch switch. But, they are certainly not load dependent. If that were true, then you couldn't put the s/c motor on an engine brake dyno (which Chrysler has always done). Belt-driven superchargers, regardless of type, work just like every other belt-driven accesory under the hood.
This multi-thread argument -> R.I.P.
"There are no substitutions for revolutions."
Member of AF's Slide Squad (Member #05) |
Alright thanks, I was thinking if I was missing anything, guess I was right all along.
