Old 07-11-2004, 06:12 PM
r8erz4life r8erz4life is offline
do subs and amps need to get "broken in"
after hooking up brand new equipment in your car, can you play it real loud, or should you wait a couple of days for them to get "broken in".
Old 07-11-2004, 06:24 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
they say you're supposed to break subs in ...... I never do
Old 07-12-2004, 05:43 PM
str8Subbin str8Subbin is offline
Send a message via AIM to str8Subbin Send a message via MSN to str8Subbin
Re: do subs and amps need to get "broken in"
i don't know if it's just me of wut but when my L5's where new they did sound as good as they do now because of the stiffness i guess. IMO i think subs should b broken in
Old 07-12-2004, 09:29 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Well, it's definitely true that speakers "break in" and start to sound different (normally better) over time, however the idea that you have to be easy on them while they break in is the topic of countless debates. I really don't have a strong opinion one way or the other, but one point that's stuck in my head throughout this whole time is this. They say the point of breaking in a sub is to loosen the suspension correct? They say the cone moving back and forth softens the suspension and that you need to be easy on it while it does this. But, how exactly is keeping the sub volume low, so the cone only moves a couple mm, going to work out the suspension at all? The only way to get it loose and get all the stiffness worked out is to stretch it out a bit, and the only way to stretch it out is to let the sub play hard.
IMO, the reason people say to let the sub break in, is not really so the sub doesn't get damaged by moving too far too early in its life, but to make sure you're keeping the volume low at the beginning so if there are any problems with the equipment or wiring you'll discover them before cranking it up and possibly doing irriversible damage.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
